| » Oven Does Not Get To Correct Temp |
Model Number: WGP34802 Brand: Whirlpool Age: More than 10 years
I have Whirlpool Accubake System electric oven, the top works fine but the oven doesn't achieve the correct heat. When set to 350 degrees it only reaches approx. 250 -260. I bought an oven thermometer to check it. To get to 350 or 400 I have to use BROIL not bake. The Range was bought December 1999. What is wrong? and what do I do about it? Ads By Google Related Models |
Did the Bake heating element get red?
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Pull the range out of the wall. Remove the rear panel and check the oven temperature sensor for continuity. Normal reading at the room temperature suppose to be about 100 Ohms.
If the reading is incorrect, replace the oven sensor. If the reading is correct then the problem is a bad control board. This part has been discontinued. In such situation it is time for a new range. - The oven sensor Part number: 8053344 Gene.
__________________
| Display Modes | |
| Help! Oven not keeping correct temp | bajaboy1 | Oven Repair (including Ranges and Cooktops) | 3 | 08-30-2011 02:21 PM |
| oven does not heat to correct temp | wawpooh | Oven Repair (including Ranges and Cooktops) | 1 | 03-08-2011 03:09 PM |
| Oven temp not correct | jeg13 | Oven Repair (including Ranges and Cooktops) | 0 | 04-01-2009 12:11 PM |
| Oven not baking at correct temp | Tracylsmith | Oven Repair (including Ranges and Cooktops) | 3 | 03-14-2009 01:44 PM |
| oven not holding correct temp | aubbie | Oven Repair (including Ranges and Cooktops) | 3 | 12-11-2008 09:53 AM |
