Discuss
Frigidare oven not heating
 in
Not sure where to find the model # The over will not heat up. There is a small side oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidare oven not heating
  #1 (permalink)
Old 09-11-2009, 05:11 PM
Junior Member
calicobess is on a distinguished road
Default Frigidare oven not heating
Brand: Frigidaire   Age: 5 - 10 years
The over will not heat up. There is a small side oven that works fine. Burners work fine too.
Any ideas? Thanks!
Ads By Google
  #2 (permalink)
Old 09-12-2009, 06:21 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
This may help you find a Model Number
Model Number Locator
__________________
  #3 (permalink)
Old 09-12-2009, 06:47 AM
Junior Member
Default
Thank you. the model # is FEF450BWC
  #4 (permalink)
Old 09-13-2009, 04:31 AM
Senior Expert
APP Volunteer
Default
Wiring diagram replacement parts for FRG FEF450BWC | AppliancePartsPros.com
Here is the wiring diagram and timer info
http://manuals.frigidaire.com/prodin.../318045323.pdf
http://manuals.frigidaire.com/prodin.../318200191.pdf
Try removing power from the unit for 10 minutes or so to see if the board will reset.
Try other functions such as timer and broil to see if anything works on the board. Timer sheet does say nothing will work unless the time of day is set.
If the unit seems to be running and just the element is not coming on then perhaps the element is burned out. On many units both the broil and bake elements come on during preheat but I could not find anything that confirmed this for this unit.
Could also be the temperature probe. Should be around 1000 ohms at room temperature. Times sheet says the unit does monitor the probe tor a fault but unfortunately does not say exactly what they are monitoring.
Here is a good site with troubleshooting help.
http://www.applianceaid.com/erange.html
__________________
  #5 (permalink)
Old 09-13-2009, 05:14 AM
Junior Member
Default
Thank you for the help. It is the heat element.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidare DBL oven-top unit intermittant jevans612 Oven Repair (including Ranges and Cooktops) 0 01-28-2010 10:42 AM
Frigidare Oven Problem lucio760 Oven Repair (including Ranges and Cooktops) 3 10-14-2009 05:21 PM
Frigidare oven display IZZY Oven Repair (including Ranges and Cooktops) 2 07-09-2009 12:46 PM
Frigidare Wall Oven wii not maintain constant temp. pcdondero Oven Repair (including Ranges and Cooktops) 0 11-13-2007 07:59 AM
Frigidare Wall Oven wii not maintain constant temp. pcdondero Oven Repair (including Ranges and Cooktops) 1 11-12-2007 07:48 PM
