Discuss
Repost: Jenn-Air oven fan takes hours to shut off
 in
Jenn-Air MODEL: sve47600w SN: 18286028VH Summary The oven fan comes on when the temperature reaches 220 degrees--regardless of whether Convect,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Repost: Jenn-Air oven fan takes hours to shut off
  #1 (permalink)
Old 06-01-2012, 11:45 AM
Junior Member
TigerDriver is on a distinguished road
Default Repost: Jenn-Air oven fan takes hours to shut off
Model Number: SVE47600W   Brand: Jenn-Air   Age: More than 10 years
Jenn-Air
MODEL: sve47600w
SN: 18286028VH
Summary
The oven fan comes on when the temperature reaches 220 degrees--regardless of whether Convect, Broil, or Bake is selected. A woman I know who has a slightly newer Jenn-Air has the same problem.
Experimental Details
If the oven is turned off as soon as the the fan comes on (i.e., 220 degrees), the fan continues to run for about 45 minutes. Leaving the oven the oven door open after turning off the oven does not decrease the fan's run-time.
If the oven is heated to a more "normal" temperature of 350-375 and remains at that temperature long enough to be useful, the fan can take a couple of hours to shut off, even if the oven door is propped open to expedite cool-down.
The time required for the fan to turn off is slightly dependent upon how long the oven has been on. That is, turning it of immediately upon reaching 350 vs two hours at 350 degrees reduces the fan run time slightly. In either case, the fan runs long after the interior of the oven is cool to the touch.
Thanks in advance,
Joe
Ads By Google
Related Models
Jenn-Air SVE47600W Range - S/c S/i Ddraft Ele
Jenn-Air SVE47600WC Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600B Range - S/c S/i Ddraft Ele
Jenn-Air SVE87600W Range - S/c S/i Ddraft Ele
Whirlpool SVF100W0
Whirlpool SVF100W1
Whirlpool SVF12FRHW00
Whirlpool SVF15NRHW00
Whirlpool SVF15NRHW01
Whirlpool SVF15NRHW02
Whirlpool SVF15NRJW00
Whirlpool SVF20NRKQ00
Whirlpool SVF60W0
Whirlpool SVF60W1
Whirlpool SVF70W0
Whirlpool SVF70W1
Whirlpool SVF75W0
Whirlpool SVF75W1
Whirlpool SVF75W2
Whirlpool SVF80W0
Whirlpool SVF80W1
Whirlpool SVF90W0
Whirlpool SVF90W1
Whirlpool SVP100W0
Whirlpool SVP50W0
Whirlpool SVP60W0
Whirlpool SVP60W1
Whirlpool SVP70W0
Whirlpool SVP75W0
Whirlpool SVP80W0
Whirlpool SVP90W0
Whirlpool SVU100W0
Whirlpool SVU100W1
Whirlpool SVU100W2
Whirlpool SVU60W0
Whirlpool SVU60W1
Whirlpool SVU60W2
Whirlpool SVU70W0
Whirlpool SVU70W1
Whirlpool SVU70W2
Whirlpool SVU80W0
Whirlpool SVU80W1
Whirlpool SVU80W2
Whirlpool SVU90W0
Whirlpool SVU90W1
Whirlpool SVU90W2
Amana SW22H Ref - SXS/I&W
Amana SW22MBG Ref - SXS/I&W
Amana SW22MBL Ref - SXS/I&W
Amana SW22MBW Ref - SXS/I&W
Amana SW25H Ref - SXS/I&W
Amana SWDT22H Ref - SXS/I&W
Amana SWDT25H Ref - SXS/I&W
Whirlpool SWF100W0
Whirlpool SWF100W2
Whirlpool SWF60W0
Whirlpool SWF60W2
Whirlpool SWF70W0
Whirlpool SWF70W2
Whirlpool SWF80W0
Whirlpool SWF80W2
Whirlpool SWF80W8
Whirlpool SWF80W9
Whirlpool SWF90W0
Whirlpool SWF90W1
Whirlpool SWF90W2
Amana SWP25H Ref - SXS/I&W
Whirlpool SWP70W0
Whirlpool SWP80W0
Whirlpool SWP90W0
Amana SWPD25H Ref - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
Whirlpool SWU100W0
Whirlpool SWU100W2
Whirlpool SWU60W0
Whirlpool SWU60W2
Whirlpool SWU70W0
Whirlpool SWU70W2
Whirlpool SWU80W0
Whirlpool SWU80W2
Whirlpool SWU90W0
Whirlpool SWU90W2
White Westinghouse SWX703AQ0 Washer - W.westinghouse
White Westinghouse SWX703AQ1 Washer - West/grupo Famsa
White Westinghouse SWX703AQ2 White Westinghouse/washer
White Westinghouse SWX703AS0 Washer - W.westinghouse
  #2 (permalink)
Old 06-01-2012, 01:11 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
According the oven diagram the cooling fan is controlled by the relay board via temperature sensor.
The sensor at room t* should show resistance 1000 - 1100 Ohm.
If it's tests OK then the relay board is not working properly.
The sensor Part number: 12001656
The relay board Part number: 12001691
Here are the breakdown diagrams and Replacement parts for Jenn-Air SVE47600W RANGE- S/C S/I DDRAFT ELE | AppliancePartsPros.com
Thank you.Keep us posted.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven takes hours to heat to only 265 degrees galaxy hunter Oven Repair (including Ranges and Cooktops) 3 05-21-2011 02:17 PM
dryer takes 2 hours to dry michalek Dryer Repair 1 03-14-2011 02:40 PM
takes 1.5 hours to wash 1 load wapiwulo Washer Repair 1 10-12-2010 02:12 PM
Takes HOURS to dry a load Tamara44 Dryer Repair 1 10-20-2008 06:38 PM
washing machine takes hours to finish washing a load kelly Monday Washer Repair 2 09-26-2007 02:42 AM
