Discuss
Digital control oven
 in
I bought this oven used so don't know how old it is though it appears to be in good
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Digital control oven
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-24-2008, 11:54 AM
BWizer BWizer is offline
Junior Member
BWizer is on a distinguished road
Angry Digital control oven
Brand: Kenmore   Age: Less than 1 year
I bought this oven used so don't know how old it is though it appears to be in good shape. However, everything seemed to work fine but I have now discovered that the oven is not actually working. I can set the oven control but within about 15 seconds it always reverts back to 100 degrees. If I keep pushing the bake icon while the temperature is set, it will remain showing the set temperature but the oven does not actually heat up. The top elements and the broiler work fine. It also appears that when the broiler is on there is a little light that is also on that I thought was the oven igniter but difficult to tell. Before calling anyone, wonder if you can give me any tips...thanks
Last edited by BWizer : 01-24-2008 at 11:56 AM. Reason: age is incorrect, don't know how old
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-24-2008, 05:13 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
i assume this is gas range because you said ignitor .if so is there a seperate bake+broil ignitor
__________________
  #3 (permalink)
Old 01-24-2008, 07:05 PM
Junior Member
Default Digital Control Oven
I can't tell if there are separate ignitors for bake and broil...the broil function works, both the control as well as the actual broiler coming on. The bake control acts like it works but, as I said, reverts to 100 degrees but never does ignite
  #4 (permalink)
Old 01-24-2008, 07:24 PM
Senior Expert
APP Volunteer
Default
the bake ignitor is under the base inside oven.you have to remove base cover to see ignitor ,
__________________
  #5 (permalink)
Old 02-04-2008, 09:55 AM
Junior Member
Default
ok, finally was able to figure it out. It looks like there is in fact separate ignitors for the bake and broil functions. The bake ignitor does not work. Please advise, thank you
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Control Earnest Oven Repair (including Ranges and Cooktops) 1 12-27-2007 12:35 PM
oven control removal ericnor Oven Repair (including Ranges and Cooktops) 1 11-10-2007 08:06 PM
Oven control ganderso Oven Repair (including Ranges and Cooktops) 1 11-07-2007 03:03 PM
Count Down Digital Timer GeorgeK Dishwasher Repair 2 10-04-2007 04:59 AM
Ge Oven Control jmajda12 Oven Repair (including Ranges and Cooktops) 1 08-15-2007 04:19 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
