Discuss
Broiler works, Bake only heats to 240 temp.
 in
Gas WALL OVEN. Broiler heats up ok, bake only heats to temp of 240. There is only a broiler ignitor,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Broiler works, Bake only heats to 240 temp.
  #1 (permalink)
Old 05-30-2012, 07:06 PM
Junior Member
AlanChk is on a distinguished road
Default Broiler works, Bake only heats to 240 temp.
Model Number: JGW8130ADW   Brand: Jenn-Air   Age: More than 10 years
There is only a broiler ignitor, no bottom oven ignitor. Is this an ignitor problem or control problem.
Ads By Google
Related Models
Jenn-Air JGW8130ADW WALLOVEN- S/C GAS
Jenn-Air JGW8130DDB WALLOVEN- S/C GAS
Maytag JGW8130DDB12 30" BUILT-IN GAS SINGLE OVEN
Maytag JGW8130DDB15 30" BUILT-IN GAS SINGLE OVEN
Jenn-Air JGW8130DDW WALLOVEN- S/C GAS
Maytag JGW8130DDW12 30" BUILT-IN GAS SINGLE OVEN
Maytag JGW8130DDW15 30" BUILT-IN GAS SINGLE OVEN
Jenn-Air JGW9130ADB WALLOVEN- S/C GAS
Jenn-Air JGW9130ADW WALLOVEN- S/C GAS
General Electric JHC56*D1 Hi-low range
General Electric JHC56*VA Hi-low range
General Electric JHC56*VB Hi-low range
General Electric JHC56G*D1 Hi-low range
General Electric JHC56G*D2 Hi-low range
Maytag JHP1060 JADE HOT PLATES (COOKING GAS)
Maytag JHP112 JHP HOT PLATE (COOKING GAS)
Maytag JHP212 JHP HOT PLATE (COOKING GAS)
Maytag JHP224 JHP HOT PLATE (COOKING GAS)
Maytag JHP336 JHP HOT PLATE (COOKING GAS)
Maytag JHP424 JHP HOT PLATE (COOKING GAS)
Maytag JHP448 JADE HOT PLATES (COOKING GAS)
General Electric JHP56*D1 Hi-low range
General Electric JHP56*V8 Hi-low range
General Electric JHP56*VA Hi-low range
General Electric JHP56G*C1 Hi-low range
General Electric JHP56G*D1 Hi-low range
General Electric JHP56G*D2 Hi-low range
General Electric JHP56G*D3 Hi-low range
General Electric JHP56G*H1 GE HI/LOW COOKING CENTER
General Electric JHP56G*H2 Hi-low range
General Electric JHP56G*J1 Hi-low range
General Electric JHP56G*J2 Hi-low range
General Electric JHP56G*J3 Hi-low range
General Electric JHP56G*M1 Hi-low range
General Electric JHP56G*V6 Hi-low range
General Electric JHP56GN1 Hi-low range
General Electric JHP56GN2 Hi-low range
General Electric JHP56GN3AD Electric range
General Electric JHP56GN3WH Electric range
General Electric JHP56GN4AD Electric range
General Electric JHP56GN4WH Electric range
General Electric JHP56GN5AD Electric range
General Electric JHP56GN5WH Electric range
General Electric JHP56GN6AD Electric range
General Electric JHP56GN6WH Electric range
General Electric JHP56GN7AD Electric range
General Electric JHP56GN7WH Electric range
General Electric JHP56N*K1 Hi-low range
General Electric JHP56N*K2 Hi-low range
General Electric JHP56N*K3 Hi-low range
General Electric JHP56N*K4 Hi-low range
General Electric JHP56V*K1 Hi-low range
General Electric JHP56V*K2 Hi-low range
General Electric JHP56V*K3 Hi-low range
General Electric JHP56V*K4 Hi-low range
General Electric JHP60G*01 Hi-low range
General Electric JHP60G*02 Hi-low range
General Electric JHP60G*03 Hi-low range
General Electric JHP60G*04 Hi-low range
General Electric JHP61G*H2 Hi-low range
General Electric JHP61G*J1 Hi-low range
General Electric JHP62G*M1 Hi-low range
General Electric JHP62GN1 Electric range
General Electric JHP62GN2 Hi-low range
General Electric JHP62GN3AD Electric range
General Electric JHP62GN3WH Electric range
General Electric JHP62GN4AD Electric range
General Electric JHP62GN4WH Electric range
General Electric JHP62GN5AD Electric range
General Electric JHP62GN5WH Electric range
General Electric JHP62GN6AD Electric range
General Electric JHP62GN6WH Electric range
General Electric JHP62N*K1 Hi-low range
General Electric JHP62N*K2 Hi-low range
General Electric JHP62N*K3 Hi-low range
General Electric JHP62N*K4 Hi-low range
General Electric JHP62N*K5 Hi-low range
General Electric JHP62V*K1 Hi-low range
General Electric JHP62V*K2 Hi-low range
General Electric JHP62V*K3 Hi-low range
General Electric JHP62V*K4 Hi-low range
General Electric JHP62V*K5 Hi-low range
Maytag JHP636 JADE HOT PLATES (COOKING GAS)
General Electric JHP63G*H1 Hi-low range
General Electric JHP63G*J1 Hi-low range
General Electric JHP63G*J2 Hi-low range
General Electric JHP63G*J3 Hi-low range
General Electric JHP63G*M1 Hi-low range
General Electric JHP63GN1 Electric range
General Electric JHP63GN2 Hi-low range
General Electric JHP63GN3AD Electric range
General Electric JHP63GN3WH Electric range
General Electric JHP63GN4AD Electric range
General Electric JHP63GN4WH Electric range
General Electric JHP63GN5AD Electric range
General Electric JHP63GN5WH Electric range
General Electric JHP63V*K1 Hi-low range
General Electric JHP63V*K2 Hi-low range
General Electric JHP63V*K3 Hi-low range
General Electric JHP63V*K4 Hi-low range
General Electric JHP63V*K5 Hi-low range
General Electric JHP64G*L1 Hi-low range
General Electric JHP64V*L1 Hi-low range
General Electric JHP65G*01 Hi-low range
General Electric JHP65G*02 Hi-low range
General Electric JHP65G*D1 Hi-low range
General Electric JHP66G*01 Hi-low range
General Electric JHP66G*02 Hi-low range
General Electric JHP67G*D1 Hi-low range
General Electric JHP67G*D2 Hi-low range
General Electric JHP67G*D3 Hi-low range
General Electric JHP67G*H1 GE HI/LOW COOKING CENTER
General Electric JHP67G*H2 Hi-low range
General Electric JHP67G*V5 Hi-low range
General Electric JHP68G*01 Hi-low range
General Electric JHP68G*02 Hi-low range
General Electric JHP69G*H2 Hi-low range
General Electric JHP69G*J1 Hi-low range
General Electric JHP69G*K1 Hi-low range
General Electric JHP69G*K2 Hi-low range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
can set bake temp however the broiler is on the whole time. Top burns bottom raw humannnature Oven Repair (including Ranges and Cooktops) 1 12-02-2011 03:49 AM
broiler works but will not work on bake maridel Oven Repair (including Ranges and Cooktops) 0 07-17-2011 06:14 AM
magic chef broiler works bake won't ignite or hold temp INTUIT711 Oven Repair (including Ranges and Cooktops) 0 02-17-2010 10:48 AM
Bake element doesn't heat, but broiler heats slightly pgf Oven Repair (including Ranges and Cooktops) 1 04-19-2009 03:30 PM
bake glows, not ignite, broiler works fine mydaddy0 Oven Repair (including Ranges and Cooktops) 3 11-28-2007 04:49 PM
