| » keypad does not work on Jenn-air range |
Model Number: JES9900BAS Brand: Jenn-Air Age: 1 - 5 years
I have a Jenn-air range. The keypad does not seem to work except for Bake, Broil, Favorites and the Enter key. It also comes up with error codes on power up: ee-214 and m-214.
Is it more likely the Control panel is the issue, or the electronic control board behind that is the issue? The Control Panel seems like not much of anything, yet many forums and posts on the web suggest that is 1 of the common causes of this issue, along with the control board. I guess I can try each to see which fixes the problem. Any guidance as to which is more likely the cause? Thanks, Mike Ads By Google Related Models |
Replacement parts for Jenn-Air JES9900BAS RANGE- S/C S/I DDRAFT ELE | AppliancePartsPros.com See the attachment for the tech sheet I cannot find the error codes you give. Have you tried unplugging or flipping the breaker off for a couple minutes to see if it will reset? Cannot say what part is to blame as the code does not come up. The normal way to troubleshoot is to check the keypad outputs. If they check out OK then replace the control board. Still a bit of a crap shoot but your odds are better. You may want to try the following. Connector Cleaning / Checking Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try.
__________________
I ordered the control panel and replaced it. This resolved the issue. All the keypad buttons now work, no error codes get shown on startup. From what I have read on various forums on the internet, those error codes generally point to the control pad. For me that worked. Took about an hour to replace it. It's good to have 2 people to do it.
I am glad to hear that you are up and running.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
| Display Modes | |
| Keypad does not work | JimNic | Microwave Repair | 0 | 03-31-2012 05:38 AM |
| Jenn Aire 27" oven keypad stopped responding | GalanOfPT | Oven Repair (including Ranges and Cooktops) | 1 | 10-13-2010 04:08 PM |
| 1/2 Keypad will not work | jeanniec | Microwave Repair | 0 | 10-02-2010 02:52 PM |
| Jenn Air #9 and #0 on keypad do not respond | Landman | Oven Repair (including Ranges and Cooktops) | 1 | 09-29-2009 02:08 AM |
| Jenn-Air Slide in Range oven does not work | peterr55 | Oven Repair (including Ranges and Cooktops) | 0 | 09-28-2009 06:10 PM |
