My oven won't light. The rod glows bright but the gas won't start therefore the oven wont light. The top burners work fine, just the oven is not working.
Groups: APP Team
Hi. In order to open the gas valve the ignitor should have the amps draw of 3.2 Amp when it's hot. You can check that with amp meter. (If you have one.) If the amperage is less - replace the ignitor Part number: WB13K21
