| » Spark model |
From the service manual.
-------------------- Spark Module 4 + 0 When properly operating, the spark module repeatedly produces a spark at the ignitor accompanied by a sharp snapping sound. 1. Turn off gas and power supply to unit. 2. Checkwiringdiagramtoverifyallterminalsandwire- connections are correct and tight with no cuts in the wiring. 3. Preparetomeasurevoltageonsparkmodulefrom terminal L to N. 4. Turn power supply back on. 5. Turn top burner to LITE position. 6. Ifnovoltageispresentonthemeter,thiswillindicate the electrical circuit is interrupted before the spark module 7. If voltage is present, then check ignitor. 8. If ignitors are ok; then replace spark module. ----------------------------------------------- Spark Module–Slide-In 1. See“Main top Removal–Slide-In”for removal. 2. Remove screws securing spark module bracket. 3. Disconnect wire terminals from spark module. 4. Replace and reassemble in reverse order.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
| Display Modes | |
| Spark on Igniter for top burner Spark is WEAK or sometimes NO spark!! | mobfather | Oven Repair (including Ranges and Cooktops) | 0 | 02-11-2011 10:10 AM |
| no spark with range viking old model | photo2u | Oven Repair (including Ranges and Cooktops) | 2 | 08-27-2010 06:42 PM |
| no spark with range viking old model | photo2u | Oven Repair (including Ranges and Cooktops) | 1 | 08-27-2010 04:25 PM |
| No spark at burner - is it spark module or switch? | Schoeman | Oven Repair (including Ranges and Cooktops) | 0 | 05-28-2010 01:18 PM |
| Is this Harper-Wyman model 6546G0007 Spark module functioning? | ginhann | Oven Repair (including Ranges and Cooktops) | 0 | 09-10-2009 02:23 PM |
