Discuss
frigidaire electric stove with controls on front
 in
I have a frigidaire electric stove that has the controls on the front above the over it is a glass
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » frigidaire electric stove with controls on front
  #1 (permalink)
Old 05-24-2012, 01:14 PM
Junior Member
barbie12000 is on a distinguished road
Default frigidaire electric stove with controls on front
Brand: Frigidaire   Age: 5 - 10 years
I have a frigidaire electric stove that has the controls on the front above the over it is a glass top and was made in 2006 the model number is fes367dsc. the right front burner will only cook on high. We want to fix it but can't get the glass top off even after taking the two screws above the oven door off and a bunch of screws on the sides off. Anyone can help me?
Ads By Google
  #2 (permalink)
Old 05-24-2012, 02:18 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
The part witch is bad is the infinite switch for the right front burner.
To get to it remove the 4 knobs, then unscrew the 4 supports directly under the knobs.
Remove the control panel and you'll see how to get to the infinite switch. On the diagram#1 it's #54 or #54A, determine yourself and order the right one.
Here are the breakdown diagrams and Replacement parts for Frigidaire FES367DSC Frigidaire/electric Range | AppliancePartsPros.com
Thank you. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 11-12-2012, 03:04 AM
Junior Member
tacohead59 is on a distinguished road
Default Frigidaire
I have a frigidaire electric stove that has the controls on the front above the oven it is a glass top and was made in around 2005. Model #GLES388CSA. The left fron burner will not work. It is part of a bridge element whereas the bridge heats up but the small front burner does not. I need some help please.
  #4 (permalink)
Old 11-12-2012, 12:31 PM
Expert
Default
Hi.
With the power off to the unit turn the corresponding burner switch (infinite) on and check contacts P2-4 for continuity (Use the multimeter and take one wire off the contacts).
If that checks OK then most likely the element is bad
Part number: 318258201
Here are the breakdown diagrams and Backguard parts for Frigidaire GLES388CSA - AppliancePartsPros.com
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Electric Ceramic Cooktop stove janoskojj Oven Repair (including Ranges and Cooktops) 0 06-13-2011 05:14 PM
Frigidaire Electric stove/cooktop's element will not shut off Morris Oven Repair (including Ranges and Cooktops) 21 06-03-2011 09:53 AM
frigidaire electric stove meroluna85 Oven Repair (including Ranges and Cooktops) 4 04-15-2011 07:11 PM
Replace glass top for Frigidaire Slide in Electric Stove baysedge1121 Oven Repair (including Ranges and Cooktops) 7 02-17-2011 11:34 AM
glass top replacement for electric frigidaire stove ronaldgreco@optonline.net Oven Repair (including Ranges and Cooktops) 0 06-29-2009 07:43 PM
