| » kitchenaid oven problem |
Model Number: Kgrs807sbl01 Brand: Kitchen Aid Age: 1 - 5 years
so, i have a kitchenaid gas range model; Kgrs807sbl01. this oven is about 4 years old and has been a piece of crap since the beginning. first the control board fried the first time we tried to do the self clean cycle. luckily it was under warranty then and it was fixed for free. then the cooling fan broke and i had to replace that for over $100. i would expect when i pay extra for supposedly high end products, they should last longer
anyway, now that my rant is over, my current problem. well, when i try to use my oven, i push the bake button, set the temp, and hit start. the oven beeps, i hear the click of the valve, and the gas start to flow. the igniter sparks 4 times then stops. i see the cooktop burners spark, but i dont see the oven or broiler igniters spark. after 30-40 seconds it does it again. then it does nothing. it does this for the oven or the broiler. after my research, i believe it is the spark control module? does this sound right? thank you for any help you can offer. Ads By Google Related Models |
Well its hard to say...since taking you on your word it sounds as if everything is working as it should, but the gas isnt igniting.
Oven beeps Gas flows Spark ignition starts gas DOESNT ignite flame sensor in spark module DOESNT detect flame, shuts off gas Oven waits for gas to clear, starts again...and again...and again. sounds to me like the spark ignitor is shorting out somewhere or isnt working at all. Its not igniting the gas, hense the spark module doesnt detect flame and does its job by stopping the gas flow. I am looking up your model now. Didnt see it listed at first. I'll update soon. EDIT--- I was wrong. I dont know this website. so last my answer about hot surface ignition was based on improper searching. We are back to the spark ignitor not working. Last edited by shouldofboughtawarranty : 05-23-2012 at 06:54 AM. |
You may want to start the troubleshooting from the gas valve (#13 at the diagram).
Label the wires connected to the three terminals at the gas valve and remove them. These terminals are for two solenoids: Bake & Broil. The upper terminal is for Broil, the middle terminal is Common and the bottom terminal is for Bake. Check each solenoid for 216 Ohms (Broil terminal to Common & Bake terminal to Common). If one of the solenoids is defective, the gas valve has to be replaced. - The gas valve Part number: 9763716 Here are the breakdown diagrams and Replacement parts for Whirlpool KGRS807SBL01 30" Freestanding GAS OVEN CONVECTION | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
Quote:
__________________
Yes, after the 4 clicks the gas would stop flowing to the burner.
When I tried to start the oven, I would hear the valve click open and gas start flowing. I would then hold a barbecue lighter next to the oven burner and it would ignite and stay lit until it reached the temperature I had the oven set at. Once it reached temperature the burner would shut off. When the temperature dropped enough it would try to rellght itself and click 4 times and would not relight. It would wait 30-40 seconds and then try to relight itself again and do that 3 or 4 times until it locked itself out. |
In such situation you probably were right about the spark module. You said that there is the same problem with both Bake and Broil and it's hard to believe that both igniters become bad at the same time.
- The spark module Part number: W10331686 Gene.
__________________
| Display Modes | |
| Kitchenaid oven control problem | Homerlp | Oven Repair (including Ranges and Cooktops) | 0 | 08-24-2011 10:32 AM |
| KitchenAid oven problem | tomwood | Oven Repair (including Ranges and Cooktops) | 0 | 05-12-2011 10:08 AM |
| kitchenAid oven problem! | dim_2007 | Oven Repair (including Ranges and Cooktops) | 0 | 04-15-2011 09:02 AM |
| Kitchenaid gas oven problem | jamesrescue1 | Oven Repair (including Ranges and Cooktops) | 0 | 02-26-2010 06:57 PM |
| Kitchenaid Oven Problem | Kitchenaid breakdown | Oven Repair (including Ranges and Cooktops) | 0 | 11-09-2009 04:18 PM |
