| » oven burner flame does not light |
Model Number: mgs5770adb Brand: Maytag Age: More than 10 years
Hi.
First check if there is 120VAC to the bake and broil ignitors.If there is 120v - replace both ignitors.If you don't fill comfortable working with "hot" appliance, unplug it and check ignitors for continuity. No continuity - replace ignitors. You will need a multimeter to run the test. If the ignitors are good locate the hi-limit thermostat with one black wire comes from the L1 of the control board and another black one from the connector block. Check the hi-limit for the continuity(take one wire off). No continuity - replace the hi- limit. The hi-limit thermostat Part number: 7403P249-60 The oven ignitor Part number: 74007498 Here are the breakdown diagrams and Replacement parts for Maytag MGS5770ADB RANGE- S/C S/I GAS | AppliancePartsPros.com Position#20 , diagram#1. Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 05-22-2012 at 03:23 PM. |
| Display Modes | |
| oven burner flame goes out | mikeclemente | Oven Repair (including Ranges and Cooktops) | 0 | 11-24-2010 07:10 AM |
| weak flame on oven burner | rjr64 | Oven Repair (including Ranges and Cooktops) | 1 | 06-21-2009 07:38 PM |
| weak flame on oven burner | rjr64 | Oven Repair (including Ranges and Cooktops) | 1 | 06-21-2009 01:25 PM |
| oven burner low flame | max | Oven Repair (including Ranges and Cooktops) | 20 | 11-06-2008 11:42 AM |
| yellow oven burner flame | nicheliz | Oven Repair (including Ranges and Cooktops) | 2 | 10-09-2007 11:11 AM |
