| » GE gas oven |
Model Number: JGBS23SEH5SS Brand: GE Age: 5 - 10 years
My oven does not turn off. I had to unplug it to get it to turn off when I plug it in same thing its still on. Now I'm not sure if it is the ignitor or the valve assembly, or am I completely wrong and its some thing else some one please help.
Thanks in advance Ads By Google Related Models |
Hi.
Check if the oven thermostat knob is not stripped or broken inside. if the knob is OK than most likely there is a bad oven thermostat. You can check it for continuity in off position. If there is continuity - replace the thermostat.Do not forget to unplug the range. The thermostat Part number: WB20K8 The knob Part number: WB03K10142 Here are the breakdown diagrams and Replacement parts for General Electric JGBS23SEH5SS Gas range | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
You are welcome.
Simon.
__________________
| Display Modes | |
