| » Maytag Stacked Dryer- gas- heat goes out |
Model Number: LSG7806AAE Brand: Maytag Age: 5 - 10 years
The flame on my stacked gas dryer goes out after it is lit by the igniter. It sounds like I need to replace the gas valve coils.
How do I access them? I removed the front panel and they seem closer to the back. Is there a back panel I should access them through? Thanks! Ads By Google Related Models |
Hi.
Does the flame cycling on and off? For how long it's stays on? When there is no flame do you see the ignitor glow? Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
The problem with your dryer is clogged exhaust vent. Remove the vent hose from the dryer and run it for one cycle. If it works fine - clean the vent, if not - clean the dryer internal vent system. Thank you. Post the results. Simon.
__________________
You are very welcome.
Simon.
__________________
| Display Modes | |
| Stacked Maytag Gas Dryer-Top | grega | Dryer Repair | 1 | 05-17-2012 01:16 PM |
| Stacked Maytag Gas Dryer | grega | Dryer Repair | 1 | 05-17-2012 01:11 PM |
| maytag sL-1 stacked drips water inside | wedge45 | Washer Repair | 1 | 08-14-2011 06:34 PM |
| Maytag Stacked problem | MiltonSnider | Washer Repair | 1 | 06-27-2011 06:17 PM |
| Maytag Washer Stacked Unit will not spin all the way | shaucan | Washer Repair | 3 | 01-07-2010 04:19 PM |
