Discuss
Instalation of ignighter for Amana Range
 in
I have ordered the ignighter and located it in the oven. I need to know how to replace it before
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Instalation of ignighter for Amana Range
  #1 (permalink)
Old 05-21-2012, 01:36 PM
Junior Member
cecoulter is on a distinguished road
Thumbs up Instalation of ignighter for Amana Range
Brand: Amana   Age: More than 10 years
I have ordered the ignighter and located it in the oven. I need to know how to replace it before it gets here. Help Please. Amana Oven ingnighter ARG7300WW P1141296NWW
Ads By Google
  #2 (permalink)
Old 05-21-2012, 04:12 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
It's not clear which one igniter you are replacing - bake or broil?
But in both cases you need to use the old brackets.
Remove the old igniter out and VERY carefully insert the new one in. The gray coil is very fragile.
For the top broiler remove the broiler out and use the old bracket and shield. Very important to keep the space between the igniter and the broiler burner surface the same as the old one.
Here are the breakdown diagram and Cavity replacement parts for Amana ARG7300WW RANGE- S/C S/I DDRAFT GAS | AppliancePartsPros.com
Good luck. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 06-06-2012, 11:36 AM
Junior Member
Default Amana
Thanks Simon, I replaced the brioler ignighter before I realized that there were two igniters. The problem I was having was with the oven, although the brioler never worked evenly and the old igniter was scortched and the wire insulation burned where they connected. Now when i turn the oven on I have no oven indicator light (the red light on the panel) it used to be red until the oven reached it's set temp. I can see that the oven igniter is glowing red, but there seems to be no gas to ignite. I turned it on and walked away for about 10 minutes and nothing happened. I did not smell the usual gas present. We are on LP here. The stove top works, seems to be no gas to the oven. What now?
  #4 (permalink)
Old 06-06-2012, 12:10 PM
Junior Member
Default Igniter
I'm about to just go buy a new range.
  #5 (permalink)
Old 06-06-2012, 01:05 PM
Expert
Default
Hi.
Check for 120v bake side of the safety gas valve when the bake ignitor is on. If the voltage is there - unplug the range, remove one lid off and check the continuity. If it's open - replace it.
If not - see if there any shut off valves right before the gas valve.
The indicator light may just burned out.
Here are the breakdown diagrams and Replacement parts for Amana ARG7300WW RANGE- S/C S/I DDRAFT GAS | AppliancePartsPros.com
Simon.
__________________
  #6 (permalink)
Old 06-06-2012, 02:05 PM
Junior Member
Default
Thanks again Simon, I will try that asap. Need some direction from hubby for this one and he is busy. Might be a couple days before I can get back to you.
  #7 (permalink)
Old 06-06-2012, 11:30 PM
Expert
Default
Take you time.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
New ignighter Whirlpool rmship Oven Repair (including Ranges and Cooktops) 4 12-13-2011 05:45 PM
Ignighter Randomly Ignighting wildbill253 Oven Repair (including Ranges and Cooktops) 1 09-08-2011 12:42 PM
replaced ignighter still no light paul wheatfield Oven Repair (including Ranges and Cooktops) 1 12-08-2010 03:32 PM
Power To Oven Ignighter grs054@mon-cre.net Oven Repair (including Ranges and Cooktops) 0 08-18-2010 01:07 PM
replace oven ignighter dsiko29315 Oven Repair (including Ranges and Cooktops) 0 03-01-2009 12:42 PM
