Discuss
ge oven, low heat
 in
oven does not heat to selected pre heat level. lower element does glow red as usual, oven heats a little,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » ge oven, low heat
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-23-2008, 07:18 PM
labdad labdad is offline
Junior Member
labdad is on a distinguished road
Post ge oven, low heat
Model Number: jkp14w0p1wg   Brand: GE   Age: More than 10 years
oven does not heat to selected pre heat level. lower element does glow red as usual, oven heats a little, but not all the way to preheat temp. Broiler seems to be fine. Problem started 3 or 4 months ago and has slowly gotten worse. Lower element now heats oven to only about 120 degrees.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven will not heat double door thermador Oven Repair (including Ranges and Cooktops) 17 01-23-2008 01:50 PM
oven won't heat up HASSELMAN Oven Repair (including Ranges and Cooktops) 2 12-03-2007 09:58 AM
Bosch 27" Dbl oven Powering on but no heat either oven badace Oven Repair (including Ranges and Cooktops) 0 12-02-2007 09:56 AM
Oven won't heat ctlopez Oven Repair (including Ranges and Cooktops) 0 10-03-2007 08:47 AM
Oven doesn't heat up mistyw Oven Repair (including Ranges and Cooktops) 0 09-07-2007 09:47 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
