Discuss
Gene, question for you
 in
Hi Gene, First off, thank you very much for taking the time to speak with me on a holiday about
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gene, question for you
  #1 (permalink)
Old 09-08-2009, 06:35 PM
Junior Member
Adnan is on a distinguished road
Default Gene, question for you
Model Number: RDFS30QB   Brand: Thermador   Age: More than 10 years
Hi Gene,
First off, thank you very much for taking the time to speak with me on a holiday about my range problem. That was very nice of you indeed!
I have confirmed that the solenoid on the front left burner is dead (no continuity on the coil). Time for a new solenoid. Hence the question.
Is it possible to replace the solenoid from the top, that is, without having to lift off the burner box? I'm hoping that all I have to do is disconnect the gas hard lines, remove the screws visible on the top that hold the bracket and pull the solenoid straight up. That should expose the wires, with enough room to unplug them.
If not, is there a trick to removing the burner box? There are so many screws and I'm sure not all have to come off.
Thanks again,
Adnan
Ads By Google
Related Models
Whirlpool RDH2030
Whirlpool RDH2036
Whirlpool RDH2330
Whirlpool RDH2336
Whirlpool RDH2630
Whirlpool RDH2636
Whirlpool RDH4330
Whirlpool RDH4336
Whirlpool RDH4630
Whirlpool RDH4636
Whirlpool RDH7330
Whirlpool RDH7336
Whirlpool RDH7630
Whirlpool RDH7636
Whirlpool RDH8330
Whirlpool RDH8630
Whirlpool RDH9330
Whirlpool RDH9630
Jenn-Air RDK100W Misc / Accessory
Jenn-Air RDK226W Misc / Accessory
Jenn-Air RDK246W Misc / Accessory
Whirlpool RDP34502
Whirlpool RDP34582
Amana RDS-648-UK Range - S/c S/i Ddraft Gas
Thermador RDSS30 S/N 9707 & UP
General Electric RE101101 Electric range
General Electric RE101102 Electric range
General Electric RE101103 Electric range
General Electric RE102101 Electric range
General Electric RE102102 Electric range
General Electric RE102103 Electric range
Whirlpool RE123
Whirlpool RE123A1
Whirlpool RE123A2
Whirlpool RE123F0
Whirlpool RE123G0
Amana RE14010C2D Room Air Conditioner
Amana RE14010C2D REV Room Air Conditioner
Amana RE14010C2DR Room Air Conditioner
Amana RE14010C2DR REV Room Air Conditioner
General Electric RE140901 Electric range
General Electric RE1409G01 Electric range
General Electric RE1409G02 Electric range
General Electric RE141001 Electric range
General Electric RE142001 Electric range
General Electric RE144001 Electric range
General Electric RE1440G01 Electric range
General Electric RE1440G02 Electric range
General Electric RE1440H01 Electric range
General Electric RE1440H02 Electric range
General Electric RE145001 Electric range
General Electric RE1450G01 Electric range
General Electric RE1450G02 Electric range
General Electric RE1450H01 Electric range
General Electric RE1450H02 Electric range
Amana RE18010C2D Room Air Conditioner
Amana RE18010C2D REV Room Air Conditioner
Amana RE18010C2DR Room Air Conditioner
Amana RE18010C2DR REV Room Air Conditioner
Amana RE18090C2D Room Air Conditioner
Amana RE18090C2D REV Room Air Conditioner
Amana RE18090C2DR Room Air Conditioner
Amana RE18090C2DR REV Room Air Conditioner
Whirlpool RE183
Whirlpool RE183A
Whirlpool RE183A1
Whirlpool RE183A2
Whirlpool RE183A3
Whirlpool RE183G0
Whirlpool RE243K0
Whirlpool RE253E
Whirlpool RE253F0
Whirlpool RE253G1
Frigidaire RE32BNL1 Frg(v2) / Electric Range
Frigidaire RE32BNL2 Frg(v2) / Electric Range
Frigidaire RE32BNM1 Frg(v3) / Electric Range
Frigidaire RE32BNW1 Frg(v1) / Electric Range
Frigidaire RE32BNW2 Frg(v1) / Electric Range
Frigidaire RE34BAA3 Frg(v4) / Electric Range
Frigidaire RE34BAA4 Frg(v9) / Electric Range
Frigidaire RE34BAA5 Frg(v3) / Electric Range
Frigidaire RE34BAF3 Frg(v3) / Electric Range
Frigidaire RE34BAF4 Frg(v8) / Electric Range
Frigidaire RE34BAF5 Frg(v2) / Electric Range
Frigidaire RE34BAH2 Frg(v1) / Free Standing Electric Range
Frigidaire RE34BAH3 Frg(v5) / Electric Range
Frigidaire RE34BAH4 Frg(v10) / Electric Range
Frigidaire RE34BAH5 Frg(v4) / Electric Range
Frigidaire RE34BAL2 Frg(v2) / Free Standing Electric Range
Frigidaire RE34BAL3 Frg(v2) / Electric Range
Frigidaire RE34BAL4 Frg(v7) / Electric Range
Frigidaire RE34BAL5 Frg(v5) / Electric Range
Frigidaire RE34BAW2 Frg(v3) / Free Standing Electric Range
Frigidaire RE34BAW3 Frg(v1) / Electric Range
Frigidaire RE34BAW4 Frg(v6) / Electric Range
Frigidaire RE34BAW5 Frg(v1) / Electric Range
  #2 (permalink)
Old 09-09-2009, 01:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Adnan,
Before you replace the solenoid perform the troubleshooting as described in the attached file.
You do not have to do anything with the burner box. Just remove the top panel. Be sure to observe the gas flow direction markings on the new valve when you install it.
- The solenoid Part number: AP2828839
- The simmer controller kit Part number: AP3672574
Here are the breakdown diagrams for the Thermador duel fuel range Model RDFS30
File Type: doc Low Simmer solenoid troubleshooting.doc (119.5 KB, 10 views)
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 09-09-2009, 07:20 PM
Junior Member
Default
Thanks Gene. However, if the solenoid shows as open, doesn't that pretty much say the solenoid is the problem (or the wire leading to the solenoid but that's not too likely)? I checked the other solenoid just to be sure and it reads 2k ohms.
Regards,
Adnan
  #4 (permalink)
Old 09-13-2009, 06:40 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Open solenoid means bad solenoid. The only question is: how good is your meter? If you are sure the readings are correct then replace the solenoid.
__________________
  #5 (permalink)
Old 09-13-2009, 09:15 PM
Junior Member
Default
Hi Gene,
I replaced the solenoid and all is well with the range now. All the evidence pointed to the solenoid from the very beginning so it was easy and painless.
Thanks again for your help.
Regards,
Adnan
  #6 (permalink)
Old 09-14-2009, 02:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome, Adnan. I'm glad you were able to fix it.
__________________
  #7 (permalink)
Old 01-19-2010, 09:32 AM
Junior Member
rosssayre is on a distinguished road
Default Replace Solenoid - Thermador
Gene,
I have placed my order for the new solenoid as I have run all your tests and that is the bad part. Might be a silly question, but I assume I have to turn off the gas to replace the solenoid, correct?
Thanks,
Ross
  #8 (permalink)
Old 01-19-2010, 12:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Ross,
It's always a good idea to turn off gas and power before you work with any appliance.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bosch dishwasher-follow up question for Gene AReed Dishwasher Repair 1 01-16-2010 02:53 PM
Hey Gene lminor204 Refrigerator & Freezer Repair 0 12-02-2009 11:09 PM
Question for Gene iamatke Refrigerator & Freezer Repair 2 12-01-2009 03:59 AM
Help Gene, No ice stjohn Refrigerator & Freezer Repair 0 02-04-2009 04:16 PM
Help Gene!! tdavis184 Washer Repair 0 04-04-2008 12:35 PM
