Discuss
Replacing Oven Door Glass
 in
Hi, I have a GE Spacesaver 27in drop-in electric range. The glass on the oven door broke. I ordered
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Replacing Oven Door Glass
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-23-2008, 02:12 PM
campster campster is offline
Junior Member
campster is on a distinguished road
Default Replacing Oven Door Glass
Model Number: JMS08BA1AD   Brand: GE   Age: 5 - 10 years
I have a GE Spacesaver 27in drop-in electric range. The glass on the oven door broke. I ordered the parts and would like some advice on how it should be replaced. If you look at the detail diagram of the oven door, the pieces that I am replacing are items 121 (Glass ovn dr) and 122 (Glass ovn dr inner).
Looking at the diagram, I cannot tell if I can install these items from the front of the door, or if I have to dissasemble the entire door to install these pieces.
Do you have any information regarding the procedure for replacing these parts?
Any help you can give me is appreciated.
I can be reached at 623 341 1193, or campster1@cox.net
Thanks,
Don
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-24-2008, 01:47 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Don,
You have to remove the door from the range.
Put it on a flat surface with the front of the door facing down.
Remove the screws held the inner door panel, remove the inner door panel and you will get access to the inner door glass.
Good luck.
__________________
Professional refrigerator repair in Irvine, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven door glass repair Barry White Oven Repair (including Ranges and Cooktops) 6 12-31-2007 06:59 PM
broken oven door glass abbyrubin Oven Repair (including Ranges and Cooktops) 1 11-28-2007 05:52 PM
Oven Door Glass Seal gman0046 Oven Repair (including Ranges and Cooktops) 0 11-23-2007 09:22 AM
Oven door inner glass Broken spealmann Oven Repair (including Ranges and Cooktops) 1 11-10-2007 09:14 PM
Oven door inner glass broken - Fossil Oven Repair (including Ranges and Cooktops) 0 10-27-2007 05:06 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
