Discuss
Maytag oven won't bake
 in
Hello, Maytag oven model# MGR 4451 BDW doesn't bake. Top burners and all else works OK. Igniter looks burnt,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag oven won't bake
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-23-2008, 11:01 AM
BestHomes BestHomes is offline
Junior Member
BestHomes is on a distinguished road
Question Maytag oven won't bake
Model Number: MGR 4451 BDW   Brand: Maytag   Age: 1 - 5 years
Hello,
Igniter looks burnt, and basically fell apart when I tried to unscrew it.
Any ideas besides igniter?
Thank you!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-23-2008, 11:19 AM
Junior Member
Default
Quote:
Originally Posted by BestHomes View Post
Hello,
Thank you!
Correction:
I meant the "Short Oven Sensor Kit" fell apart when I unscrewed it.
Any ideas besides replacing it?
Thank you !!!
  #3 (permalink)
Old 01-24-2008, 11:11 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The oven temperature sensor has to be replaced first before we can proceed with further diagnosis.
- The part number for the oven temperature sensor is AP204835
__________________
Professional appliance repair services in Orange County, California.
  #4 (permalink)
Old 01-24-2008, 11:18 AM
Junior Member
Default
Will do, Gene.
Thanks again !!!!
Nice board and GREAT techs !!!
  #5 (permalink)
Old 01-25-2008, 06:01 PM
junkyard38 junkyard38 is offline
Junior Member
junkyard38 is on a distinguished road
Default Amanna Gas range oven heating problems/
Amanna Model ARG7600WW P1143333NWW.
Cleaned the unit and all went fine this is the last time the oven worked prior.
Broiler works fine and lites off .Canceled the operation.
Cleaning feature works fine an lites off. Canceled the operation.
Stove top functions fine.
Remedies I have tried per a repair man.
Replaced the electronic module, oven does not function.
Because the unit did not bake at the required temp I needed to add 5-10 degrees to the temp setting, I also replaced the temp probe at the same time.
I cannot find a in line fuse nor any other part that has anything to do with the baking cycle. There are no burnt off wires at the terminals.
This repair advice i received has cost over $200.00 and still no oven to bake in. If anyone out there can shed some light what I need to do it would be appreciated to get this oven functioning.
Thank you ,Don
  #6 (permalink)
Old 01-25-2008, 06:46 PM
Junior Member
Default
Junkyard,
You posted your problem as a "reply" to my problem.
You'll get better exposure if you continue posting under your thread (if you already have one started) or click on "POST NEW TOPIC" and post your problem.
Good luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag CRE9400CCE Bake element LEAD wire COLOTOM Oven Repair (including Ranges and Cooktops) 1 12-24-2007 01:25 PM
Oven will not bake sna1imj Oven Repair (including Ranges and Cooktops) 3 11-12-2007 12:04 PM
oven wont bake radgy Oven Repair (including Ranges and Cooktops) 3 10-12-2007 07:59 AM
Oven Will Not Bake tony Oven Repair (including Ranges and Cooktops) 6 08-01-2007 05:21 PM
Oven doesnt bake ChrisF Oven Repair (including Ranges and Cooktops) 0 07-26-2007 05:25 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
