Hello,
My first post here. I did search and found some similar issues.
Just bought this unit used, plugged in and ran the Self-Cleaning program. Heated up and worked for about 2 hours before I left for about an hour.
When I returned the display is blank and buttons unresponsive. The stove works and electricity to stove was verified. Oven door is locked and oven has now cooled.
Thanks in advance for the help!
Pull the range out of the wall, remove the rear panel and check for continuity the thermal fuses (#23 & #37 on the diagram). Here are the breakdown diagrams for the Whirlpool range Model KGRA806PSS00
