Help! Lost power & now my Thermador PGR366ZS oven won't turn on
Our town lost power and when the power returned, the oven doesn't turn on. The burners are all fine. The oven does not turn on...there is no noise at all. The oven indicator light blinks 2 secs and then the heating indicator light blinks 2 secs and keeps repeating this pattern.
The oven light works when you open the door. Please help, I need to bake and would love to be able to fix this oven. Thanks. |
Hi.
The code you are describing: "The memory in the control board is out". Replace the board.You can find it at the back of the range. The control board Part number: 676192 Here are the breakdown diagrams and Replacement parts for Thermador PGR366ZS | AppliancePartsPros.com . Thank you. Post the results. Simon. |
| All times are GMT -7. The time now is 02:19 PM. |
