I have a Jennair (maytag model # JJW8630AAB) double wall oven. A door hinge recently broke & I ordered replacement hinges ( Order # 2536022 ). The door doesn't completely close now - should I also have replaced the hinge receptacle also? If so, what is the correct one to order? Also, I tried to do a self cleaning by pushing the door closed afer I had installed the new hinges and initating the cleaning cycle. The door wouldn't latch and the control panel said 'clean'. Should I replace the receptacles and then see what happens or can you point me in a direction to check out what I need to do to determine why it didn't lock . Thanks........John
Groups: APP Team
Hi. In a lot of cases the receptacles need to be replaced together with the hinges. The receptacles Part number: 74008015
