| » GE Oven Range "Locked Door" problem |
Model Number: JBP82W0H2WW Brand: GE Age: 5 - 10 years
Hi:
I have a GE oven range and recently I have started having a problem where the oven range door does not close. When I try to close it, it displays "locked door" on the panel and the lock motor seems to be working continuously as I hear the motor sound. What is wrong? And what needs to be done to fix it? Thanks, Hit Ads By Google Related Models |
Hi Hit,
You may want to start the troubleshooting from checking the switches at the door latch assembly. If any of the switches is bad, replace the door latch assembly. If there is nothing wrong, replace the control board. - The door latch assembly Part number: WB14T10016 - The control board Part number: WB27T10473 Here are the breakdown diagrams and Replacement parts for General Electric JBP82WH2WW Electric range | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Oven control panel says "locked door" and does not work. Need new control panel. | ferhan | Oven Repair (including Ranges and Cooktops) | 3 | 08-15-2011 06:45 PM |
| FC "locked door" flashes. Door not locked. | vicmastro | Oven Repair (including Ranges and Cooktops) | 1 | 02-18-2011 03:49 PM |
| Ge Oven "locked Door" Flashing | GTS1211 | Oven Repair (including Ranges and Cooktops) | 0 | 11-21-2010 08:47 AM |
| Kenmore oven defaults from "bake" to "broil" | big blue | Oven Repair (including Ranges and Cooktops) | 0 | 11-06-2010 03:26 PM |
| oven "moaning" sound then faint "poof" sound; later, large "poof" popped door open | samej71 | Oven Repair (including Ranges and Cooktops) | 2 | 03-24-2010 07:05 AM |
