While the oven was in sel-cleaning mode the controls went dead and now the door cannot be opened or the controls activated.
Groups: APP Team
Hi. You will need to pull out the range, unplug the unit, turn the gas off. Remove the rear cover and locate the hi-limit thermostat. By pass it and turn the power on. If the clock works - replace the hi-limit. The hi - limit thermostat Part number: 8300802
