This blog was posted 4/2/12 Originally Posted by Gene Make sure the inner door liner, oven door frame and door hinges are not bend. The door hinges are not adjustable.
Gene,
Thanks for the input. FYI, I found a rotating stop on each hinge. I rotated the stops down to the hinge and closed the door. Then I applied closing pressure on the door and the hinges realigned themselves. The oven door now closes like new
Read more: http://forum.appliancepartspros...close.html#ixzz1tNRa1vnZ http://forum.appliancepartspros.com How do I even get to the hinges and these totating stops?
THIS FORUM IS DEAD!!!!!!! |
