Have double wall gas oven lower oven needs ignitor and will order, at the same time upper oven does not turn on. You turn the knob nothing happens not even the lite turns on. Thanks John
Groups: APP Team
Hi.
Look at the left dial of the oven clock. Make sure the arrow is on MAN. Turn the middle dial arm until it will pop out.
If that not going to help, then it,s most likely the oven thermostat (no longer available).
Thank you. Post the results.
Simon.
