I have been using this gas oven for 3 years, with no problem. I believe that the digital panel may not be working properly. I can turn the DIAL for oven temp, it will only heat up to 200 degrees. This model has 7 buttons, & a temp. dial on the back upright part of the stove. The oven HEATS. And it's heating NOW, rather quickly !!! I've never used the broiler, just checked it...it will broil on low... The range top works great.The knob on the right is to control oven & broiler temp .This Range is old, but my mom didn't use it long, she became ill...Later, my dad used it occasionally. Maybe it's just old. PLEASE , if you can, HELP !!! :confused: Thanks ...Julie .
