Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Hood repair (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/46889-hood-repair.html)
dwtrilogy 09-04-2009 01:43 PM
Hood repair
If I need to call in a professional, I will, but it seems like it should be an easy fix. I went to push the light button and the entire control panel fell IN. I can't see a seam or screws to remove the overhang part of the hood to get the panel placed back through the hole. Any thoughts? THANKS!
Gene 09-04-2009 03:47 PM
1 Attachment(s)
Hopefully the attached installation instruction and the breakdown diagrams and Replacement parts for THERMADOR PHE36US | AppliancePartsPros.com will help.
dwtrilogy 09-04-2009 06:04 PM
Thanks, Gene. So you must think I can do it! Joyce
Gene 09-05-2009 03:28 PM
At least you can try. What do you have to loose?
