Discuss
I have an OLD Modern Maid oven above stove
 in
I have a modern maid stove and oven. Oven is above stove, and my dishwasher is below stove. My oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » I have an OLD Modern Maid oven above stove
  #1 (permalink)
Old 04-15-2012, 01:52 PM
Junior Member
staceyjarvis69 is on a distinguished road
Unhappy I have an OLD Modern Maid oven above stove
Model Number: DEI212 2   Brand: Modern Maid   Age: More than 10 years
I have a modern maid stove and oven. Oven is above stove, and my dishwasher is below stove. My oven was working one day and then it quit working, it barely heats up now even on highest setting. It also has a grounded outlet just below the oven part which is now dead. I also on have two operational burners. I cant seem to find anything relating to my oven/stove combo and am desperate to know if i can get it fixed and how to do so. Its Serial Number is 27164, i fear it is very old. What do I do? How can I fix it? Or do i just need to replace it?
Ads By Google
Related Models
Frigidaire DEIDH1 Frg(v8) / Gas and Electric Dryers
Frigidaire DEIDL1 Frg(v9) / Gas and Electric Dryers
Frigidaire DEIDW1 Frg(v7) / Gas and Electric Dryers
Frigidaire DEIFL0 Frg(v2) / Electric Dryer
Frigidaire DEIFW0 Frg(v1) / Electric Dryer
Frigidaire DEILL1 Frg(v2) / 27 " Electric Dryer
Frigidaire DEILL2 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILL3 Frg(v2) / 27 " Electric Dryer
Frigidaire DEILL4 Frg(v2) / 27 " Electric Dryer
Frigidaire DEILL5 Wwh(v2) / 27 " Electric Dryer
Frigidaire DEILW1 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW2 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW3 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW4 Frg(v1) / 27 " Electric Dryer
Frigidaire DEILW5 Frg(v1) / 27 " Electric Dryer
Frigidaire DEISFL0 Frg(v4) / Electric Dryer
Frigidaire DEISFL1 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFL2 Frg(v2) / 27 " Electric Dryer
Frigidaire DEISFL3 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFL4 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFL5 Frg(v4) / 27 " Electric Dryer
Frigidaire DEISFW0 Frg(v3) / Electric Dryer
Frigidaire DEISFW1 Frg(v3) / 27 " Electric Dryer
Frigidaire DEISFW2 Frg(v2) / 27 " Electric Dryer
Frigidaire DEISFW3 Frg(v3) / 27 " Electric Dryer
Frigidaire DEISFW4 Frg(v3) / 27 " Electric Dryer
Frigidaire DEISFW5 Frg(v3) / 27 " Electric Dryer
Norge DEJ20800 Dryer - Ele
Norge DEJ20824 Dryer - Ele
Norge DEJ20825 Dryer - Ele
Norge DEJ208A Dryer - Ele
Norge DEJ208H Dryer - Ele
Norge DEJ208W Dryer - Ele
Norge DEJ25400 Dryer - Ele
Norge DEJ25424 Dryer - Ele
Norge DEJ25425 Dryer - Ele
Norge DEJ25426 Dryer - Ele
Norge DEJ25427 Dryer - Ele
Norge DEJ254A Dryer - Ele
Norge DEJ254H Dryer - Ele
Norge DEJ254W Dryer - Ele
Norge DEJ26400 Dryer - Ele
Norge DEJ26424 Dryer - Ele
Norge DEJ26425 Dryer - Ele
Norge DEJ26426 Dryer - Ele
Norge DEJ26427 Dryer - Ele
Norge DEJ264A Dryer - Ele
Norge DEJ264H Dryer - Ele
Norge DEJ264W Dryer - Ele
Norge DEK201AC Dryer - Ele
Norge DEK201WC Dryer - Ele
Norge DEK204AC Dryer - Ele
Norge DEK204HC Dryer - Ele
Norge DEK204WC Dryer - Ele
Menu Master DEL10D  Commercial Microwaves
Menu Master DEL10E  Commercial Microwaves
Norge DEL202A Dryer - Ele
Norge DEL202C Dryer - Ele
Norge DEL202H Dryer - Ele
Norge DEL202W Dryer - Ele
Norge DEL202WC Dryer - Ele
Norge DEL203 Dryer - Ele
Norge DEL203A Dryer - Ele
Norge DEL203AC Dryer - Ele
Norge DEL203H Dryer - Ele
Norge DEL203HC Dryer - Ele
Norge DEL203W Dryer - Ele
Norge DEL203WC Dryer - Ele
Norge DEL204A Dryer - Ele
Norge DEL204H Dryer - Ele
Norge DEL204W Dryer - Ele
Norge DEL253A Dryer - Ele
Norge DEL253H Dryer - Ele
Norge DEL253W Dryer - Ele
Norge DEL263A Dryer - Ele
Norge DEL263H Dryer - Ele
Norge DEL263W Dryer - Ele
Norge DEM202A Dryer - Ele
Norge DEM202AC Dryer - Ele
Norge DEM202H Dryer - Ele
Norge DEM202HC Dryer - Ele
Norge DEM202W Dryer - Ele
Norge DEM202WC Dryer - Ele
Norge DEM204 Dryer - Ele
Norge DEM204 REV A Dryer - Ele
Norge DEM204 REV B Dryer - Ele
Norge DEM204 REV C Dryer - Ele
Norge DEM204A Dryer - Ele
Norge DEM204AC Dryer - Ele
Norge DEM204H Dryer - Ele
Norge DEM204HC Dryer - Ele
Norge DEM204W Dryer - Ele
Norge DEM204WC Dryer - Ele
Norge DEM205A Dryer - Ele
Norge DEM205AC Dryer - Ele
Norge DEM205H Dryer - Ele
Norge DEM205W Dryer - Ele
Norge DEM205WC Dryer - Ele
Norge DEN202A Dryer - Ele
Norge DEN202AC Dryer - Ele
Norge DEN202W Dryer - Ele
Norge DEN202WC Dryer - Ele
Norge DEN203A Dryer - Ele
Norge DEN203AC Dryer - Ele
Norge DEN203W Dryer - Ele
Norge DEN203WC Dryer - Ele
Norge DEN204A Dryer - Ele
Norge DEN204GV Dryer - Ele
Norge DEN204KA Dryer - Ele
Norge DEN204KV Dryer - Ele
Norge DEN204KW Dryer - Ele
Norge DEN204V Dryer - Ele
Norge DEN204VC Dryer - Ele
Norge DEN204W Dryer - Ele
Norge DEP222VC Dryer - Ele
Norge DEP223M Dryer - Ele
Norge DEP223V Dryer - Ele
Norge DEP224M Dryer - Ele
Norge DEP224MC Dryer - Ele
Norge DEP224V Dryer - Ele
  #2 (permalink)
Old 04-17-2012, 08:05 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I was hoping someone else would jump in who had info on this unit.
I have no info so cannot be of much help.
It does sound like a wire or connection has failed since you lost the oven, the receptacle and 2 stove top elements all at the same time.
I am assuming that the other stove top elements work OK.
I would remove power from the unit and trace the wiring to/from the effected parts. Trying to find a connection/wire that is common to them.
If all elements (oven and stove top) do not heat up correctly then odds are you have a power problem.
Try flipping the breaker off/on slowly a couple times. The breaker should actually be two breakers ganged together. If your house has fuses check both of them.
If that does nothing then you will have to check for 240 volts at the oven/stove top.
Unless you have some experience working with electricity I would leave this to a pro.
240 volts is lethal!!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Modern Maid Upper Oven aliciafino Oven Repair (including Ranges and Cooktops) 0 11-28-2011 01:42 PM
Modern Maid Double Gas Oven kevinlogo Oven Repair (including Ranges and Cooktops) 1 10-01-2011 02:42 PM
Modern Maid Oven won't heat rollsfixer Oven Repair (including Ranges and Cooktops) 3 12-02-2010 10:53 AM
Modern Maid Electric Oven JW Speaks Oven Repair (including Ranges and Cooktops) 1 06-04-2009 11:54 AM
Modern Maid Oven Repair Buck Bac Oven Repair (including Ranges and Cooktops) 1 01-30-2009 06:24 PM
