embdenb
#1 Posted : Thursday, September 3, 2009 10:48:19 AM(UTC)
embdenb
I know this subject has been discussed before, however is there a solution for an oven, approx two years old where the hinges have been replaced twice and the door has never stayed closed?:mad:
I am about to purchase my third set of hinges and the plan is to somehow make the springs stronger before putting them in.
Can anyone offer an alternative to fix this problem?
#2 Posted : Thursday, September 3, 2009 2:42:19 PM(UTC)
You can find an explanation, cause and solution on this problem in the Maytag Technical bulletin. If you need the correct part number for the kit then post the serial number of the oven.
Here are the breakdown diagrams and Replacement parts for JENN-AIR JMW9530DAS | AppliancePartsPros.com
embdenb
#3 Posted : Thursday, September 3, 2009 3:28:07 PM(UTC)
embdenb
Thanks for the reply. I would like the correct part number for the repair kit. The serial number is 20877861GX.
#4 Posted : Thursday, September 3, 2009 5:30:06 PM(UTC)
You need two hinges Part number: AP4101029
and two hinge receptacles Part number: AP4100063
If you just replaced the hinges with the above part number then you probably need just the receptacles.
embdenb
#5 Posted : Friday, September 4, 2009 4:52:29 AM(UTC)
embdenb
Thanks Gene. Will purchase the hinge and receptacles. I guess I have to pull the oven out to replace the receptacles
britinva
#6 Posted : Saturday, February 18, 2017 8:06:17 AM(UTC)
britinva
I'm having issues with door not making tight seal.....found this old thread but the link to the Maytag Technical Bulletind is no longer valid. Does anyone still have or know how to get correct part no for the hinges for
Model: JMW9530DAS
Serial: 22537114JL
Thanks,
Mark
#7 Posted : Saturday, February 18, 2017 5:07:36 PM(UTC)
Hello, Mark.
Sorry for the broken link. I fixed it.
You would need two hinges Part number: AP6011189
and two receptacles Part number: AP6011249
Good luck.
britinva
#8 Posted : Saturday, February 18, 2017 6:24:31 PM(UTC)
britinva
Thanks Gene
