The Lower bake element wont heat up. The Broiler heats up fine. The element is good. What else can cause the bake element not to work.
Tim
Here are your parts Replacement parts for Kenmore 66595012102 | AppliancePartsPros.comSee the attachment for the tech sheet Check the wiring from the control board to the element. If it is OK and the unit stays or takes a long time to reach set point in preheat bake with just the broil cycling then odds are that the control board is toast. |
THIS FORUM IS DEAD!!!!!!! |
