I have a ceran top Freestanding range, and the front left burner light stays on all the time, but the burner does not heat up at all. Is this something that I can fix myself?
Most likely the problem is a bad infinite switch for this burner. - If this burner has a dual heating element then the switch Part number: AP3751872
