| » Magic Chef Oven does not reach indicated temp |
Model Number: 38HA-6TVW Brand: Magic Chef Age: More than 10 years
Oven has an electronic digital oven temp set. Recently noticed that food was not cooking properly so put a manual thermometer in oven. Actual oven temp averages 150-200 degrees less than digital indicator. Element glows red until oven "thinks" it has reached temperature. Oven will hold temperature but never reaches set temp.
FYI- High and low broiler element works fine. Any suggestions? Ads By Google Related Models |
Quote:
Ohm out your oven sensor, it should read approx. 1100 ohms at room temperature. The sensor is the probe protruding out the back wall of the oven. If it checks good, then I'm going to say the clock is the problem. If memory serves me right you could calibrate these clocks, but it was only good for about 35 degrees +/-, no where near the amount you're talking. I've included a pic of the oven sensor, but there were a couple of different clocks used on this model, depending whether there were any other numbers on the ID plate. Part number: AP4009009
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Magic Chef oven temp probe thermos | Duane22 | Oven Repair (including Ranges and Cooktops) | 0 | 02-04-2010 04:35 PM |
| Magic Chef oven , broiler, will not turn on NO temp display | jeffL | Oven Repair (including Ranges and Cooktops) | 0 | 11-24-2009 11:08 AM |
| Magic Chef oven temp | bioblues | Oven Repair (including Ranges and Cooktops) | 3 | 11-07-2009 08:58 AM |
| Magic Chef Oven Not Heating to Set Temp | djandm1 | Oven Repair (including Ranges and Cooktops) | 1 | 10-10-2008 09:26 AM |
