my upper oven element is hanging down. the support bracket is still wrapped around it, but not holding it up. I don't know if the bracket is broken or just needs to be fastened to the roof of the oven. Any Help?
Below is the support. Part number: AP2126398
Click on the picture for more views. You should then be able to expand them so you can see what it should look like. Looks like there is a loop at one end perhaps that has broken. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Below is the support. Part number: AP2126398
Click on the picture for more views. You should then be able to expand them so you can see what it should look like. Looks like there is a loop at one end perhaps that has broken. Doesn't look like mine and still doesn't tell me how it mounts. Do you have installation instructions?
Sorry but it is a Tappan so I do not have any info on it.
Often one end slides into a slot. This then lets the other end go into it's slot . |
