Having a problem with the stove on this Jenn Air svd48600b. Often with the oven warms up to 350F it starts beeping at and shuts off. It flashes either just an FC error code, or FC and F5.
It is often possible to get the oven to work again if you wait 10-15min and cycle the power.
I imagine something is wrong with a heat sensor? The temperature sensor responsible for displaying temperature on the control panel seems fine though.
One other detail, even when the oven doesn't shut off at hot temperatures, the fan comes on and stays on for over an hour after the oven is turned off.
Does anyone know if there is a different temperature sensor that might cause this? Is there a specific electronics board that may be leading to this problem. when it heats up.
