Discuss
Oven Element Shot - But Won't Shut Off
 in
I USED MY OVEN YESTERDAY AND IT WORKED FINE. AFTER USING IT, I TURNED IT OFF AND WENT ON MY
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Element Shot - But Won't Shut Off
  #1 (permalink)
Old 01-21-2008, 08:45 AM
captuper captuper is offline
Junior Member
captuper is on a distinguished road
Default Oven Element Shot - But Won't Shut Off
Model Number: JBP66G   Brand: GE   Age: More than 10 years
I USED MY OVEN YESTERDAY AND IT WORKED FINE. AFTER USING IT, I TURNED IT OFF AND WENT ON MY MERRY WAY. LATER LAST EVENING I WENT BY THE OVEN AND FELT HEAT FROM IT, AND WHEN I OPENED THE DOOR THE OVEN WAS HOT. THE ELEMENT ON THE BOTTOM WAS GLOWING IN TWO SPOTS (APPARENTLY CRACKED), BUT THE OVEN WAS SHUT OFF!!! I HAD TO TURN OFF THE BREAKER TO SHUT IT DOWN. AFTER IT COOLED, I SEPERATED THE CRACKED ELEMENT AND TURNED THE BREAKER BACK ON FIGURING WITH A BREAK IN THE CIRCUIT, IT WOULD NO LONGER HEAT. WRONG!!!!! WHEN I OPENED THE OVEN DOOR TO CHECK IT, THERE WAS STILL A SPOT GLOWING ON THE ELEMENT. ?????
I HAVE ORDERED A NEW ELEMENT FOR THE OVEN, BUT AM WONDERING WHY IT WAS STILL HEATING AFTER THE OVEN KNOB WAS TURNED TO OFF??
ANYONE HELP???
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-21-2008, 05:40 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem caused by the shorted control board.
In order to provide the right part number for the control board I need the complete model number of the unit. The model number you posted is incomplete.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Electric stove/cooktop's element will not shut off Morris Oven Repair (including Ranges and Cooktops) 13 10-24-2008 02:54 PM
my oven is shut down munequita4u2 Oven Repair (including Ranges and Cooktops) 7 05-29-2008 01:49 PM
Broiler will not shut off-With oven off POTENTATE Oven Repair (including Ranges and Cooktops) 1 10-29-2007 06:10 PM
Oven will not shut off jhoium Oven Repair (including Ranges and Cooktops) 3 10-02-2007 02:32 PM
Element won't shut off Morris Oven Repair (including Ranges and Cooktops) 0 08-01-2007 06:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
