| » Oven doesn't heat up, but broiler works fine |
Model Number: 68-4587-87 Brand: Admiral Age: 5 - 10 years
About two to three months ago, I started receiving the F-1 error on my oven. After about two days the intermittent error ceased. A few weeks later I began noticing that the oven would not heat up to the temperature requested. Now, it is unable to heat up on it's own. However, I can turn on the broiler and heat the temperature up to the desired degree and then switch it over to an oven setting. As my items are cooking it obviously looses the tempurature, but it's been getting the job done. How can I find out what I need to replace to get the oven back to normal usage?
Thank you Ads By Google Related Models |
Hi Michelle,
The first thing I would do is remove the bake element and check for burned out wires. If there is nothing wrong then remove one of the wires from the heating element and check for 120V between each wire and the ground. Post the results. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Oven Won't Heat But Broiler Works | SuzannePowell | Oven Repair (including Ranges and Cooktops) | 0 | 12-07-2009 01:35 PM |
| Gas pulsating in oven. Broiler works fine. | TimW2 | Oven Repair (including Ranges and Cooktops) | 4 | 09-26-2009 05:43 PM |
| ignitor glows bright orange but no gas to oven, broiler works fine | browndeer | Oven Repair (including Ranges and Cooktops) | 2 | 08-07-2009 07:33 AM |
| Broiler works - oven does not heat | JL Molding Design | Oven Repair (including Ranges and Cooktops) | 3 | 12-10-2008 10:35 PM |
| Whirlpool Oven won't heat stove works fine | tnearman | Oven Repair (including Ranges and Cooktops) | 2 | 10-18-2007 09:13 AM |
