Discuss
Viking range top trips GFI
 in
My Viking range top trips the GFI when plugged in. I have unplugged the stove top and the GFI works
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Viking range top trips GFI
  #1 (permalink)
Old 08-31-2009, 01:56 PM
Junior Member
Dscully is on a distinguished road
Default Viking range top trips GFI
Model Number: VGRT4826GSS   Brand: -other-   Age: 1 - 5 years
My Viking range top trips the GFI when plugged in. I have unplugged the stove top and the GFI works fine. I am not familiar with the ignition system. Is this something I can repair or does a part need to be replaced? Can a pretty handy guy like myself do the fix or do I need an appliance pro?
thanks
Related Models
Amana VHC-2 RANGE- S/C S/I DDRAFT GAS
General Electric VISR208DT8WW Washer
General Electric VISR208DTAWW Washer
General Electric VISR309JT5AA Washer
General Electric VISR309JT6AA Washer
General Electric VISR309JT8AA Washer
General Electric VISR309JTAAA Washer
General Electric VJSR2070T2AB Washer
General Electric VJSR2070T2WB Washer
General Electric VJSR2070T3AB Washer
General Electric VJSR2070T3WB Washer
General Electric VJSR2070T5AB Washer
General Electric VJSR2070T5WB Washer
General Electric VJSR2070T6AB Washer
General Electric VJSR2070T6WB Washer
General Electric VJSR2070T8AB Washer
General Electric VJSR2070T8WB Washer
General Electric VJSR2070TAAB Washer
General Electric VJSR2070TAWB Washer
Gaggenau VK111-610
Gaggenau VK230-610
General Electric VKSR2100T2WW Washer
General Electric VKSR2100T3WW Washer
General Electric VKSR2100T5WW Washer
General Electric VKSR2100T6WW Washer
General Electric VKSR2100T8WW Washer
General Electric VKSR2100TAWW Washer
General Electric VKXR4100T2WW Washer
General Electric VKXR4100T3WW Washer
General Electric VKXR4100T5WW Washer
General Electric VKXR4100T6WW Washer
General Electric VKXR4100T8WW Washer
General Electric VKXR4100TAWW Washer
Gaggenau VL021-707
Gaggenau VL022-707
Gaggenau VL023-707
Gaggenau VL030-707
Gaggenau VL031-707
Gaggenau VL040-707
Gaggenau VL041-707
Gaggenau VL051-707
Gaggenau VL330-707
Gaggenau VL331-707 211100 UP
Gaggenau VL331-707upto 211099
General Electric VLD4209L15BB Dishwasher
General Electric VLD4209L15SS Dishwasher
General Electric VLD4209L15WW Dishwasher
General Electric VLD4209L20BB DISHWASHER
General Electric VLD4209L20SS DISHWASHER
General Electric VLD4209L20WW DISHWASHER
General Electric VLLR1020T0WO Washer
General Electric VLLR1020T1WO Washer
General Electric VLSR1090G0WW Washer
General Electric VLSR1090G2WW Washer
General Electric VLXR1020A0WO Washer
General Electric VLXR1020A1WO Washer
General Electric VLXR1020A2WO Washer
General Electric VLXR1020A3WO Washer
General Electric VLXR1020A4WO Washer
General Electric VLXR1020A4WW Washer
General Electric VLXR1020A5WO Washer
General Electric VLXR1020D0WO Washer
General Electric VLXR1020D2WO Washer
General Electric VLXR1020D5WO Washer
General Electric VLXR1020T2WB Washer
General Electric VLXR1020T3WB Washer
General Electric VLXR1020T4WB Washer
General Electric VLXR1020T5WB Washer
General Electric VLXR1020T8WB Washer
General Electric VLXR1020TAWB Washer
Thermador VM-275
Thermador VM-300
Thermador VM-350
Thermador VM-400
Thermador VM-410 HOOD VENTILATOR
Thermador VM-450
Magic Chef VM11A-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11B-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11B-8PDY MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11BN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11C-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11CN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11D-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11D-8P-DY MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11DN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11EB-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11EV-8P MWAVE- MOUNTED UNDER CABINET
Maytag VM12AB MWAVE- MOUNTED UNDER CABINET
Maytag VM12AM MWAVE- MOUNTED UNDER CABINET
Maytag VM12AV MWAVE- MOUNTED UNDER CABINET
Maytag VM12AV-1 MWAVE- MOUNTED UNDER CABINET
Thermador VM410
Magic Chef VM9B-8 MWAVE- MOUNTED UNDER CABINET
Frigidaire VP21AW3 Tap(v1) / Gas Range
Frigidaire VP21AW3-23 Tap(v2) / Gas Range
Frigidaire VP21AW4 Tap(v3) / Gas Range
Frigidaire VP21AW4-23 Tap(v4) / Gas Range
Frigidaire VP30AW3 Tap(v1) / Gas Range
Frigidaire VP30AW3-23 Tap(v2) / Gas Range
Frigidaire VP30AW4 Tap(v3) / Gas Range
Frigidaire VP30AW4-23 Tap(v4) / Gas Range
Frigidaire VP30BW2 Tap(v1) / Gas Range
Frigidaire VP30BW2-23 Tap(v2) / Gas Range
Frigidaire VP30BW3 Tap(v3) / Gas Range
Frigidaire VP30BW3-23 Tap(v4) / Gas Range
Frigidaire VP30CW2 Tap(v1) / Gas Range
Frigidaire VP30CW2-23 Tap(v2) / Gas Range
Frigidaire VP30CW3 Tap(v3) / Gas Range
Frigidaire VP30CW3-23 Tap(v4) / Gas Range
Frigidaire VP36DW2 Tap(v1) / Gas Range
Frigidaire VP36DW2-23 Tap(v2) / Gas Range
Frigidaire VP36DW3 Tap(v3) / Gas Range
Frigidaire VP36DW3-23 Tap(v4) / Gas Range
Thermador VQT1000 VENTILATOR
Thermador VQT600 VENTILATOR
Thermador VR-1000 VENTILATOR
Thermador VR-1400 VENTILATOR
Thermador VR-600
Thermador VR1000
Gaggenau VR122-612
  #2 (permalink)
Old 08-31-2009, 02:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely there is nothing with the range. It is not recommended by the manufacturer to use a GFI. You have to use a regular outlet connected to a regular circuit breaker.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 08-31-2009, 03:11 PM
Junior Member
Default
Thanks Gene. It was professionally installed 3 years ago and all has been OK until this weekend. I thought it was a bad GFI so I replaced it. As soon as I plug in the range the GFI trips. I wonder if I could experiment with an extension cord to a different circuit, although most in the kitchen are GFI protected??
  #4 (permalink)
Old 08-31-2009, 05:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If you have the Installation instructions came with the range then you can check the electrical requirements there. If you do not have one, I found the instructions on line and it 's written there on page 12: "Do not use GFI circuit".
__________________
  #5 (permalink)
Old 07-22-2014, 10:34 AM
Junior Member
jhdsuon is on a distinguished road
Default Viking Range now Trips GFCI after 3+ years
Does anyone have an answer to why a Viking 6 burner range would all of sudden start tripping GFCI. Yes, i know it's supposed to be on its own dedicated 20amp circuit, but it worked fine on a GFCI multi receptable circuit. The builder hooked it up that way and i had no say in the matter.
Just looking for any answers before i start tearing up my house to install a dedicated line. I could remove the GFCI and remove all other "load" receptacles in the series, but then i would lose three outlets that are useful.
Thanks.
  #6 (permalink)
Old 07-23-2014, 02:47 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I do not have an easy answer for you.
When does it trip?
As soon as you plug the unit in or when you do a certain operation.
This may help you narrow it down if it trips on a certain operation then look in that area.
Could be a bad GFI.
If you have another/different GFI circuit try running it on that line.
If not a bad GFI then there is probably moisture or dirt that runs from the live side of the line to ground.
I would try running the unit on a non GFI circuit perhaps heating it up for a while will clear a moisture problem.
If you can get at the controls/boards easily try heating them up a couple times using a hair dryer. Do not get them too hot.
If it is a dirt problem then finding it will be very difficult.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
viking range professional sam4444 Oven Repair (including Ranges and Cooktops) 8 06-20-2016 05:18 PM
Viking Range Door Hinge TableRocker Oven Repair (including Ranges and Cooktops) 6 09-30-2011 03:44 PM
Range trips gfi numbers Oven Repair (including Ranges and Cooktops) 5 06-26-2009 11:30 AM
Viking Range stovetop will not spark Pat C Oven Repair (including Ranges and Cooktops) 0 03-11-2009 07:18 AM
Viking range winthropenterprises Oven Repair (including Ranges and Cooktops) 3 07-07-2008 12:58 PM
