Tom2012
#1 Posted : Monday, April 9, 2012 11:18:19 PM(UTC)
Tom2012
The LR of the Bridged Radiant elements is not working. What part do i need to replace. The LFand the bridge are working fine!
Simon / APP Team
#2 Posted : Tuesday, April 10, 2012 11:32:36 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You are looking at bad bridge element or the infinite switch.
To determine which one you need to remove the cooktop from the cabinet, take the screws around the perimeter out and lift the top.
With power off check the L/R element first visually for brakes and then using the multimeter, check the continuity at the element.
If you don't see anything wrong with the element, turn on the power (only if you feel OK to do the "life"test), turn on the burner switch and check for 230v at the element in question.
Reading 230v - replace the element.
No voltage - replace the infinite switch.
The bridge element Part number: AP2826918
The infinite switch Part number: AP2832042
Her are the breakdown diagrams and Replacement parts for Thermador CE365UB CERAN ELECTRIC COOKTOP | AppliancePartsPros.com
Thank you. Post the results.
Simon.
