when new bulb touches socket it burns out. I want to know if installing a light assembly is the fix and if so can I do that myself. are instructions for the novice included when this part is purchased?
What kind of the light bulb you tried to install?
Have you turned "off" the power to the range prior to a light bulb installation?
Have you removed the old light bulb undamaged or it broke?
