| » Thermador Built in Oven Completely Dead |
Model Number: SMW272 Brand: Thermador Age: 5 - 10 years
My seven-year old Thermador SMW272 initially showed what seems to be a fairly common symptom: the display got very dim. Next came a repeated beeping and shortly thereafter it died completely, with no display and no response from any of the buttons. Using advice from the online forums, I've replaced the display and the main power board using this kit: http://www.************.com/SmartSea...5865&PPStack=1.
Unfortunately, the oven is still dead, despite the new parts. I've checked and double-checked the wiring of the new board and checked to be sure that it's receiving power. What else I should try? |
firstly, you should make sure that you have 220vac coming to the oven.. then you should check if YOU broke the 4 pin plug on the touch pad ( solder joint is usually cold ) may need to replace touchpad...
__________________
regards jim |
| Display Modes | |
| GE Built-In Oven Doesn't Always Preheat | markwahl | Oven Repair (including Ranges and Cooktops) | 0 | 01-19-2008 09:54 PM |
| built in electric oven | JOY | Oven Repair (including Ranges and Cooktops) | 3 | 01-08-2008 12:16 PM |
| Thermador built in oven - relay board | meganluk | Oven Repair (including Ranges and Cooktops) | 0 | 11-21-2007 06:21 PM |
| Thermador oven dead | Cat | Oven Repair (including Ranges and Cooktops) | 3 | 11-19-2007 03:37 PM |
| No Power - completely dead | Zeaon | Microwave Repair | 1 | 09-15-2007 09:19 AM |
