top burners work fine but oven and broiler won't light. From your website, I tested the gas valve/regulator with an ohmmeter. I got 190 ohms on both circuits (1 to 2, 2 to 3). Some more info: after unplugging the range, testing the gas valve, and plugging it back in, the oven did light. So I thought it might be a reboot fix, a la my computers (no such luck). It is in failure mode now. At first I had gas present with no spark. Now there is no gas and no spark at the oven ignitor. Retesting the gas valve again gives proper readings on both circuits: 190 ohms. Can you provide a troubleshooting flow chart for this model, and any advice? Thanks.
