| » GE glass stove top large burner not working |
Model Number: JBP79WY2 Brand: GE Age: More than 10 years
The large burner is a two element burner that has stopped working. I replaced the element but hat didnt fix the issue. Apparently I have a problem in the large/small burner switch or the rotating heat knob. Any ideas on how to test this circuit or find the root problem.
Thank you. Ads By Google Related Models |
Quote:
You can check the switch if you have a volt meter. Remove power to unit and then gain access to the back side of the switch. Once you have it safely accessed, turn the switch on and go across H1 and H2 on the switch, you should read 240V. If you don't, make sure you have it across L1 and L2. If you have it there the switch is bad. If you do have it across H1 and H2 then you've got a wire problem between the switch and the burner. Below is a pic of the switch. Part number: AP2023620
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
This burner has the ability to be the full 9" or a smaller 6" burner. To change between the burner size is a second switch that looks to be a single pull.
How do you test this switch to see if it is good? |
Quote:
Can't get my hands on a wiring diagram for that model. How many terminals are on the switch? I see it in the parts breakdown but I can't tell what's happening inside of it. What were the results for the previous test I mentioned?
__________________
I just got home and started testing the single pole single throw switch that changes the burner from a 6" to a 9". The switch has continuity when it is on the 9" setting. It seems to be working fine.
I than pulled the wires off the main burner switch so I could read the markings and reinstalled the wires. I plugged in stove to 240 V and conducted a voltage test on the H1 and H2 lines and I had 244V. I also noticed the burner turned on! So as right now it working - but how and why? The only difference is I removed a few wires and placed them back on. All connections seemed solid so I am perplexed. Any suggestions? |
| Display Modes | |
| GE Glass Top Large Burner not working well | Jetgo | Oven Repair (including Ranges and Cooktops) | 0 | 11-28-2009 12:01 PM |
| Help! Whirlpool stove rear burner not working! | jasonjasonjason | Oven Repair (including Ranges and Cooktops) | 2 | 11-26-2009 06:23 AM |
| Single Burner out on Glass Top Stove | badabing | Oven Repair (including Ranges and Cooktops) | 7 | 04-29-2009 03:00 PM |
| GE Stove Glass top Crack in middle of back burner | pkorisa | Oven Repair (including Ranges and Cooktops) | 2 | 03-27-2009 10:49 AM |
| Glass top stove left fron burner stopped working | lalem | Oven Repair (including Ranges and Cooktops) | 1 | 01-19-2009 05:56 AM |
