| » clock/control panel |
Model Number: W132B Brand: Jenn-Air Age: 5 - 10 years
I had a F-1 code. Was told I needed a new control panel. I got one & repalced it. When I turned on the power nothing lights up on the panel. It is like I have no power to the clock. I am pretty sure all the wires went back correct as I marked then as I took them off.
When the old one acted up it did have a display, and I could reset it but the beep & error code came back. Ads By Google Related Models |
Quote:
Make sure you have 120v across the black and white wire on the transformer, which is mounted on the board. I'd also suggest you double check you wiring. On the below parts breakdown link the last two pages show the wiring. Model w132b
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Don't have a detailed drawing of the board, but if memory serves me right, it was either 12v or 24v. Sounds like you got a bad board.
__________________
| Display Modes | |
| clock/ timer or control panel? | stp57 | Oven Repair (including Ranges and Cooktops) | 7 | 01-15-2010 03:41 AM |
| GE Clock Control Panel | TeresaO | Oven Repair (including Ranges and Cooktops) | 0 | 12-16-2009 08:58 PM |
| replacing clock/control panel | DawnAnn | Oven Repair (including Ranges and Cooktops) | 5 | 06-24-2009 01:00 PM |
| Can I replace a control panel/clock myself? | naudnice | Oven Repair (including Ranges and Cooktops) | 1 | 02-05-2009 03:56 PM |
| Clock on Control Panel Intermittently Fails | MadamWong | Oven Repair (including Ranges and Cooktops) | 0 | 04-25-2008 02:03 PM |
