Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Dual Burner Issue (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/46203-dual-burner-issue.html)
ptcgarner 08-30-2009 12:12 PM
Dual Burner Issue
Both of my dual size burners heat on large no matter switch position. They do work temperature wise from low to hi ok but when the small size burner is selected it only works large. I hope you can help. Thanks.
Gene 08-31-2009 01:43 PM
Most likely the problem is a bad switches for these burners but I would check the heating elements for continuity as well.
- The dual element infinite switch Part number: AP4008679
Here is the Service manual.
Here are the breakdown diagrams and Replacement parts for JENN-AIR JES9800AAW | AppliancePartsPros.com
