Discuss
No Oven/Surface
 in
My range just up and quit. Not sure where to start on the troubleshooting. Clock, display buttons etc. seem to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » No Oven/Surface
  #1 (permalink)
Old 04-07-2012, 09:19 AM
Junior Member
not_sure is on a distinguished road
Default No Oven/Surface
Model Number: MER5750   Brand: Maytag   Age: 5 - 10 years
Clock, display buttons etc. seem to work fine.
It's a smooth top. We were using the surface at the time it stopped. Now no lights indicating a burner is on and no heat on surface.
If I turn on the oven, it allows me to set the temp and preheat light comes on, but no heat through the element.
I have turned off the breaker and turned back on (CTL-ALT-DEL), no help.
Any suggestions would be awesome. I'm not afraid to dig into it, but not really sure where and have no good documentation.
TIA
Ads By Google
Related Models
Maytag MER5750AAA Range - S/c F/s Ele
Maytag MER5750AAB Range - S/c F/s Ele
Maytag MER5750AAW Range - S/c F/s Ele
Maytag MER5750BAB Range - S/c F/s Ele
Maytag MER5750BAQ Range - S/c F/s Ele
Maytag MER5750BAW Range - S/c F/s Ele
Maytag MER5751AAB Range - S/c F/s Ele
Maytag MER5751AAQ Range - S/c F/s Ele
Maytag MER5751AAS Range - S/c F/s Ele
Maytag MER5751AAW Range - S/c F/s Ele
Maytag MER5751ACS Range - S/c F/s Ele
Maytag MER5751ACW Range - S/c F/s Ele
Maytag MER5751BAB Range - S/c F/s Ele
Maytag MER5751BAQ Range - S/c F/s Ele
Maytag MER5751BAS Range - S/c F/s Ele
Maytag MER5751BAW Range - S/c F/s Ele
Maytag MER5752AAB Range - S/c F/s Ele
Maytag MER5752AAQ Range - S/c F/s Ele
Maytag MER5752AAS Range - S/c F/s Ele
Maytag MER5752AAW Range - S/c F/s Ele
Maytag MER5752ACB Range - S/c F/s Ele
Maytag MER5752ACS Range - S/c F/s Ele
Maytag MER5752ACW Range - S/c F/s Ele
Maytag MER5752BAB Range - S/c F/s Ele
Maytag MER5752BAQ Range - S/c F/s Ele
Maytag MER5752BAS Range - S/c F/s Ele
Maytag MER5752BAW Range - S/c F/s Ele
Maytag MER5754QAQ Range - S/c F/s Ele
Maytag MER5754QAW Range - S/c F/s Ele
Maytag MER5755AAB Range - S/c F/s Ele
Maytag MER5755AAQ Range - S/c F/s Ele
Maytag MER5755AAW Range - S/c F/s Ele
Maytag MER5755QAB Range - S/c F/s Ele
Maytag MER5755QAQ Range - S/c F/s Ele
Maytag MER5755QAS Range - S/c F/s Ele
Maytag MER5755QAW Range - S/c F/s Ele
Maytag MER5755QCB Range - S/c F/s Ele
Maytag MER5755QCW Range - S/c F/s Ele
Maytag MER5765QAB Range - S/c F/s Ele
Maytag MER5765QAF Range - S/c F/s Ele
Maytag MER5765QAN Range - S/c F/s Ele
Maytag MER5765QAQ Range - S/c F/s Ele
Maytag MER5765QAW Range - S/c F/s Ele
Maytag MER5765RAB Range - S/c F/s Ele
Maytag MER5765RAQ Range - S/c F/s Ele
Maytag MER5765RAS Range - S/c F/s Ele
Maytag MER5765RAW Range - S/c F/s Ele
Maytag MER5765RCB Range - S/c F/s Ele
Maytag MER5765RCS Range - S/c F/s Ele
Maytag MER5765RCW Range - S/c F/s Ele
Maytag MER5770AAA Range - S/c F/s Ele
Maytag MER5770AAB Range - S/c F/s Ele
Maytag MER5770AAQ Range - S/c F/s Ele
Maytag MER5770AAW Range - S/c F/s Ele
Maytag MER5770ACA Range - S/c F/s Ele
Maytag MER5770ACB Range - S/c F/s Ele
Maytag MER5770ACQ Range - S/c F/s Ele
Maytag MER5770ACW Range - S/c F/s Ele
Maytag MER5770BAB Range - S/c F/s Ele
Maytag MER5770BAQ Range - S/c F/s Ele
Maytag MER5770BAW Range - S/c F/s Ele
Maytag MER5770BCB Range - S/c F/s Ele
Maytag MER5770BCQ Range - S/c F/s Ele
Maytag MER5770BCW Range - S/c F/s Ele
Maytag MER5775AAB Range - S/c F/s Ele
Maytag MER5775AAQ Range - S/c F/s Ele
Maytag MER5775AAW Range - S/c F/s Ele
Maytag MER5775QAB Range - S/c F/s Ele
Maytag MER5775QAF Range - S/c F/s Ele
Maytag MER5775QAN Range - S/c F/s Ele
Maytag MER5775QAQ Range - S/c F/s Ele
Maytag MER5775QAS Range - S/c F/s Ele
Maytag MER5775QAW Range - S/c F/s Ele
Maytag MER5775QCB Range - S/c F/s Ele
Maytag MER5775QCF Range - S/c F/s Ele
Maytag MER5775QCQ Range - S/c F/s Ele
Maytag MER5775QCS Range - S/c F/s Ele
Maytag MER5775QCW Range - S/c F/s Ele
Maytag MER5775RAB Range - F/s Std Ele
Maytag MER5775RAQ Range - F/s Std Ele
Maytag MER5775RAS Range - F/s Std Ele
Maytag MER5775RAW Range - F/s Std Ele
Maytag MER5775RCB Range - S/c F/s Ele
Maytag MER5775RCF Range - S/c F/s Ele
Maytag MER5775RCQ Range - S/c F/s Ele
Maytag MER5775RCS Range - S/c F/s Ele
Maytag MER5780BAB Range - S/c F/s Ele
Maytag MER5780BAQ Range - S/c F/s Ele
Maytag MER5780BAS Range - S/c F/s Ele
Maytag MER5780BAW Range - S/c F/s Ele
Maytag MER5870AAA Range - S/c F/s Ele
Maytag MER5870AAB Range - S/c F/s Ele
Maytag MER5870AAQ Range - S/c F/s Ele
Maytag MER5870AAW Range - S/c F/s Ele
Maytag MER5870ACA Range - S/c F/s Ele
Maytag MER5870ACB Range - S/c F/s Ele
Maytag MER5870ACW Range - S/c F/s Ele
Maytag MER5870BAB Range - S/c F/s Ele
Maytag MER5870BAQ Range - S/c F/s Ele
Maytag MER5870BAW Range - S/c F/s Ele
Maytag MER5870BCQ Range - S/c F/s Ele
Maytag MER5870BCS Range - S/c F/s Ele
Maytag MER5870BCW Range - S/c F/s Ele
Maytag MER5875QAB Range - S/c F/s Ele
Maytag MER5875QAF Range - S/c F/s Ele
Maytag MER5875QAN Range - S/c F/s Ele
Maytag MER5875QAS Range - S/c F/s Ele
Maytag MER5875QCB Range - S/c F/s Ele
Maytag MER5875QCF Range - S/c F/s Ele
Maytag MER5875QCS Range - S/c F/s Ele
Maytag MER5875QCW Range - S/c F/s Ele
Maytag MER5875RAB Range - F/s Std Ele
Maytag MER5875RAF Range - F/s Std Ele
Maytag MER5875RAN Range - F/s Std Ele
Maytag MER5875RAS Range - F/s Std Ele
Maytag MER5875RCB Range - S/c F/s Ele
Maytag MER5875RCF Range - S/c F/s Ele
Maytag MER5875RCQ Range - S/c F/s Ele
Maytag MER5875RCS Range - S/c F/s Ele
Maytag MER5875RCW Range - S/c F/s Ele
  #2 (permalink)
Old 04-07-2012, 08:42 PM
Junior Member
Default
Turned out to be the outlet. One of the hot legs had a bad connection so the control board got 110, but the 240 wasn't there for operating stove top or oven.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Surface burners and oven not working karen7957 Oven Repair (including Ranges and Cooktops) 2 12-05-2010 10:33 AM
surface unit works oven doesnt andyatlanta Oven Repair (including Ranges and Cooktops) 0 06-12-2010 10:29 AM
Surface Burners work OK, Oven dead, no control light turns on for oven Whirlyone Oven Repair (including Ranges and Cooktops) 0 06-07-2010 07:24 AM
surface switch for GE Oven lauerbac@suffolk.lib.ny.u Oven Repair (including Ranges and Cooktops) 0 05-06-2008 10:23 AM
Maytag Gas Oven.....Surface Burners ALL Ignite..... Tony D. Oven Repair (including Ranges and Cooktops) 6 12-21-2007 10:08 AM
