Recently bought a new Frigidaire convection oven. Installed without a problem, converted to LP gas. I now need to adjust the burner flames. I remove the knobs to access the adjustment screw inside the tube, but I cannot for the life of me find a screwdriver with a thin enough shaft that is also long enough. Any suggestions on where to find one? Is there a special tool for this? Owners manual make sit seem so easy, "insert flat blade screwdriver...". What they don't tell you is that it needs to be very thin, almost eyeglass screwdriver-thin. Thanks in advance
