E2 F3 error
Receiving a error code E2 F3. Broiler element reads 18.6 ohms Oven bake element reads 21 ohms Oven Temp sensor reads 140 ohms I am suspecting the timer ERC control. Any advice would sure help. Seems that Whirlpool part # 3195183 is discontinued.
Quote:
The "F3-E2" means "Bake range overtemperature". The first failure suspect in such situation is the oven sensor and the test result you posted proves it. The normal reading for the oven sensor should be about 1100 Ohms at the room temperature.
- The oven sensor Part number: AP3130719 Here are the breakdown diagrams and Replacement parts for Whirlpool RF374PXDQ1 30" ELECTRIC RANGE | AppliancePartsPros.com Gene. |
| All times are GMT -7. The time now is 09:57 AM. |
