| » Magic chef oven broke, need help. |
Model Number: 3468VVV Brand: Magic Chef Age: 5 - 10 years
Hello. My oven will not light, the broiler will light and the ignitor on oven lights. Could you tell me what part I need to fix it. I cannot use my oven. I have a magic chef.
Thanks Cassie Ads By Google Related Models |
Quote:
Below is the part #. Part number: AP4012072
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
I have already switched ignitor from browler to oven, the ignitor glows and dosnt seem to be the problem. Is there anything else it could be. |
Quote:
If you have a amprobe you should be reading right around 3.5 amps. Also check the outlet the range is plugged in to. Should be close to 120v. If it's on the low side that can cause the amperage to be low. The gas safety valve has a bi-metal in it that warps when the amp draw is correct, which in turn allows the gas to flow. Obviously when the gas hits the hot ignitor you've got flame. Make sure the orfice on the valve is clean and clear. Also make sure where the ignitor mounts, it's in line with the port holes on the burner where the gas can come in contact with the ignitor.
__________________
| Display Modes | |
| Magic Chef oven | cinson | Oven Repair (including Ranges and Cooktops) | 0 | 08-16-2009 07:24 AM |
| Magic Chef RV oven | fcherman | Oven Repair (including Ranges and Cooktops) | 0 | 08-05-2009 01:44 PM |
| magic chef oven | rschell100 | Oven Repair (including Ranges and Cooktops) | 0 | 07-22-2009 10:30 AM |
| Need help with my Magic Chef oven | cuz7878 | Oven Repair (including Ranges and Cooktops) | 0 | 05-02-2009 08:26 AM |
| Magic Chef Oven | lessrob | Oven Repair (including Ranges and Cooktops) | 0 | 10-16-2008 09:11 PM |
