The lights on this unit have always been iffy - with one or the other failng to light reliably. I suspected it was just cheapo sockets as a bit of jiggling would usually rectify it ... for a while.
The fan always operated normally.
Recently the lights quit altogether and the light indicator on the control panel is also dead. The indicator lights for the fans still light and there is an audible relay click when changing speeds - however the fans no longer operate.
It seems like it always a cheesy little circuit board that fails in modern appliances.
Broan wants $180 for the control panel on a two yr old $250 appliance.
