Discuss
Oven temp off by approx 150deg?
 in
Hi - Had problem with upper electric oven temp varying by +/- 100deg, so I replaced the thermostat and it appears to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven temp off by approx 150deg?
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-18-2008, 05:52 PM
DPalmerston DPalmerston is offline
Junior Member
DPalmerston is on a distinguished road
Question Oven temp off by approx 150deg?
Model Number: 7858XVA   Brand: Magic Chef   Age: 5 - 10 years
Hi -
Had problem with upper electric oven temp varying by +/- 100deg, so I replaced the thermostat and it appears to be holding firm temps now, the only problem is that it is just about 150deg low (set 350, temp 205, set 500, temp 350). While I was replacing the thermostat, I checked the condition of the coil connections and they look good, tight, not burned, frayed or disconnected. It will hold 350 for 30 mins now while set at 500.
I don't see any way to calibrate for 150 deg that is obvious, am I missing it?
What would be the next step in troubleshooting? Could a faulty element be causing this?
The lower oven has completely separate controls and works fine.
Thanks for any help...
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven temp off shea11 Oven Repair (including Ranges and Cooktops) 0 12-03-2007 12:11 PM
oven temp too low leon Oven Repair (including Ranges and Cooktops) 2 10-05-2007 03:18 PM
oven temp runs away ricky303hunting Oven Repair (including Ranges and Cooktops) 3 09-27-2007 03:32 AM
Oven temp control fred1329 Oven Repair (including Ranges and Cooktops) 2 09-16-2007 09:49 AM
Oven Temp 60F low George Whitmore Oven Repair (including Ranges and Cooktops) 0 08-13-2007 03:08 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
